Need help with Corbeau A4 install
Old May 3, 2007 | 09:44 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Need help with Corbeau A4 install
I tried to install tonight but the seat will not fit due to the seat adjustment mechanism pressing up against the seatbelt retractor mechanism on the floor next to the door rail. The mounting bracket/ rails say 97-04 Corvette and the holes line up fine but as I said there is clearance issues. Any help is greatly appreciated.
Cajun
Old May 3, 2007 | 11:25 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
You have to put the passenger seat on the drivers side and the drivers seat on the passenger side. So the leaver to recline the seat is on the inside next to the consol.....Hope this helps
Old May 3, 2007 | 11:36 PM
bk's Avatar
bk
They will fit that way. Still tight, but it works. good luck.
Old May 4, 2007 | 08:49 AM
0Cajun @ Edgyvette
Former Vendor
AWESOME, I thought that might be it, just too lazy to dismount an remount both LOL Thanks
Cajun
Old May 4, 2007 | 09:52 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I've also been told that if you look on the base of the seat frame, it has 2 sets of mounting holes. If you remove the seat from the frame and swap mounting locations, it will allow you to install the seats in the side they are supposed to be mounted in. Its also my understanding that you need to file down the seatbelt latch bolt. If you dont, it wont fit next to the tunnel.
I have NOT done this personally, but I have read about it here more than a couple of times.
Cajun
Old May 4, 2007 | 11:39 AM
0Cajun @ Edgyvette
Former Vendor
The seat belt bolts push on the center console but not really bad. It fits I just have to switch the seats around. Thanks for the info.
Cajun
Old May 5, 2007 | 04:35 AM
Switchbarrel's Avatar
Switchbarrel
Default Corbeau A4's
Here's what I did (okay, I had a friend mill it for me)
and hey look...they mount on the correct side. None of this mounting them with the recliner on the wrong side. Corbeau should be ashamed of themselves calling these brackets "C5 specific". What a joke.
Old Jul 18, 2007 | 11:12 PM
triblk6spd's Avatar
triblk6spd
I agree 100%. The fit for C5 specific brackets is horrible. I had to mount mine on the wrong sides as well. Theu look hella cool though.
Old Jul 23, 2007 | 06:52 PM
TLKSCHP's Avatar
TLKSCHP
How do these seats feel compared to the factory standard seats? I was thinking of buying a set. Also where is the best place to get the slides? Any weight savings?
Old Jul 23, 2007 | 09:54 PM
NemesisC5's Avatar
NemesisC5
Cool seats, it would be nice to have them with factory electric functions like memory
Old Jul 23, 2007 | 10:04 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
How spoiled we are.
Old Jul 25, 2007 | 06:47 PM
TLKSCHP's Avatar
TLKSCHP
Who are you guys ordering the rails from for the A4's?
To Need help with Corbeau A4 install
