header question
Old Jul 25, 2007 | 05:32 PM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default header question
i installed lgs on wed and it took me abuot 9 hours, it not an easy job by yourself, anyway i and using the rear o2s in the front do you keep them inthe same pipe and how about the crossing of the wires or do i just hook them up the way the front o2s where set up by pluging into the same side that o2 senor is on. or do i still keep then crossed like rhey where in the rear. i have the wire adapters to hook the rears to the fronts just not sure how. thanks jim
Old Jul 25, 2007 | 05:38 PM
vettenuts's Avatar
vettenuts
The fronts do not cross. The rears do cross.
Are you having Don tune the car? If so, just leave the rears out and plug the holes. He will tune them out anyhow. I bought some plugs at Verocious motorsports, part number O2PS (which includes the bung if you need them later). They are right in Delaware so you will get them fairly quick.
Old Jul 25, 2007 | 05:39 PM
Last C5's Avatar
Last C5
Old Jul 25, 2007 | 06:26 PM
JAMESNORTHPROV
thats what i did, now i can get her tuned at deez. i already had the plugs they came with headers. thanks jim
Old Jul 25, 2007 | 07:05 PM
vettenuts's Avatar
vettenuts
That sure makes things easy It will throw some codes until its tuned, just make sure any codes are for the rears and not the fronts. Let us know how you make out with the tune and the results
To header question
