Brake Bleeders?
Old May 8, 2007 | 08:19 AM
Nick1's Avatar
Nick1
Default Brake Bleeders?
Where is the best place to get the quick bleeders from? Thanks
Old May 8, 2007 | 03:41 PM
SilvaDragon's Avatar
SilvaDragon
I used the SpeedBleeders, but this product is actually MUCH more useful:
http://www.motiveproducts.com/
Old May 8, 2007 | 04:32 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
I use speed bleeders for bleeding, and the Motvie power bleeder when flushing.
Old May 8, 2007 | 08:32 PM
Nick1's Avatar
Nick1
Thanks, but I have a good bleeder kit, just looking for the speed bleeders.
Old May 9, 2007 | 10:02 AM
SilvaDragon
OK, then, here you go:
http://www.speedbleeder.com/automobile_applications.htm
Old May 9, 2007 | 01:46 PM
B-ras's Avatar
B-ras
I need to pick up a set of these too. Would everyone recommend the stainless? More than twice the price of mild steel, but that only means $8 x 4, so does it make sense?
Old May 9, 2007 | 03:36 PM
rws.1's Avatar
rws.1
I bought my stainless steel ones directly from Speedbleeders at the above noted web address...
Old May 9, 2007 | 04:11 PM
B-ras's Avatar
B-ras
^Thanks!
Old May 9, 2007 | 04:42 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
They positively work
Old Aug 16, 2007 | 03:15 AM
Shylor's Avatar
Shylor
Isn't repeated bleeding the same as flushing if you put enough fluid through? And if so then why spend the money for a power bleeder if speed bleeders do the same thing for less.
Old Aug 16, 2007 | 09:09 AM
MadMaxZ06's Avatar
MadMaxZ06
I purchased a set of Goodridge speed bleeders from Lingenfelter (LPE) for $16.00: http://www.lingenfelter.com/store/spdbld.html and I have used them several times with great results (read, no leaks).
- Max
Old Aug 16, 2007 | 09:17 AM
rws.1's Avatar
rws.1
the only difference is you have to pump the pedal to move the fluid with speed bleeders but what i do with them is to flush the brake lines...
I keep the brake fluid reservoir open and keep pumping until what come sout at the caliper is clear and then give about another 10 pumps.
Old Aug 16, 2007 | 11:13 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
If you are going to use the stainless ones from Speedbleders ( which I use ) I would recommend using a good anti seize.
Old Aug 16, 2007 | 11:17 AM
berryj's Avatar
berryj
I just picked up a set from my local auto store. Are these any different from the online speedbleeder.com ones?
Old Aug 22, 2007 | 09:41 PM
Shylor's Avatar
Shylor
I just stripped the head of one of my bleeders and broke my wrench. I was trying to keep the OEM bleeders, got only the rear right done and was working on the front right when this happened. Guess now is a good time to purchase a set of speedbleeders.
Any thoughts on how I can get the bleeder off now? I assume I could use a locking vice grip plier.
Old Aug 23, 2007 | 04:19 PM
sgm2004's Avatar
sgm2004
Shylor, if you have enough of the bleeder left try a flare wrench for removing the bleeder. These types of wrenches are used on tubing connectors and carb connection. They get a better bite on the flange sholders of the part. I used them to remove the bleeders on all my 75 calibers worked great. Mine were standard though and C5's may be metric. Thanks
sgm2004
Old Aug 23, 2007 | 04:25 PM
Shylor's Avatar
Shylor
I should have mentioned I was trying to bleed the brakes on a 96.
Old Aug 30, 2007 | 12:36 AM
Shylor's Avatar
Shylor
I just finished installing the Speedbleeders and glad I also ordered the bleeder hose. Other than the Speedbleeders being a tad longer than the OEM bleeders, they sure made the whole process very easy. The Speedbleeder hose was much easier to use than the old plastic hose I had been using.
The only thing I didn't understand was that the Speedbleeders needed an 11mm wrench while the OEM bleeder took a 10mm. Not that big of a deal, just wondering why they went up a size.
To Brake Bleeders?
