Sour interior smell with A/C
Old May 12, 2007 | 06:29 PM
02HREBlue's Avatar
02HREBlue
Default Sour interior smell with A/C
Anyone know the cause and how to fix? How does one also change the cabin air filter on a C5? Taking the car to a dealer is not an acceptable answer either -
Old May 12, 2007 | 09:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sorry,,,the C5 does NOT have a cabin filter. It does however draw air in through the cowl in front of the windshield. On the drivers side there is a well for the wiper motor. It has three rubber drains. If they clog up, the trach in that well will rit and stink!! The AC HVAC will draw in that smell.
Old May 12, 2007 | 10:03 PM
T VETTE's Avatar
T VETTE
Great photos.
Old May 12, 2007 | 10:46 PM
02HREBlue's Avatar
02HREBlue
I will look into it! Thanks so much. I hope it is this simple, except that the car is a 2002 and has only 11k and is always kept inside under a car cover. I hope this is the problem. Great pictures. This kind of help is why I love the Corvette forum.
Old May 13, 2007 | 08:12 AM
Oldvetter's Avatar
Oldvetter
There are aerosal cans of air conditioner cleaner that you can spray into intake and outlet ducts. They clean and disinfect the system.
There is another fix, a kit that runs the air conditioner fan after the car is turned off. It drys out moisture so mold can't grow. It is a little strange to hear your interior fan come on after you car is off, but it works.
Old May 13, 2007 | 08:39 AM
gpracer1's Avatar
gpracer1
Dont forget the evap drain, it might be clogged.
Old May 13, 2007 | 09:23 AM
JBI's Avatar
JBI
A great trick to avoid mildew in the system is to run the fan on High with AC off until warm air starts to come out, just before you reach your destination.
I do this everytime I go home after using the AC for that day. You don't have to do it on every ride in your car, just the end of the day and that should avoid mildew growth.
Old May 13, 2007 | 09:40 AM
02HREBlue's Avatar
02HREBlue
Where is the evap drain? Thanks for the help
Old May 13, 2007 | 10:13 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out this sticky link:
http://forums.corvetteforum.com/show....php?t=1246715
It in there!!
Old May 13, 2007 | 10:29 AM
02HREBlue's Avatar
02HREBlue
It in there!!
Thanks--I will look!
To Sour interior smell with A/C
