Setting dual climate control?
Old May 13, 2007 | 11:09 PM
bondo man's Avatar
bondo man
4th Gear
Default Setting dual climate control?
I have a 98 C5 with dual climate control. I bought the car used three
years ago.It had 17000 miles on it and was in near perfect condition.My
question is when I want to change the temp, I can only move the temp up or down 1 degree at a time.Is this normal?
bondo man
Old May 14, 2007 | 09:34 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Each click of the dial should be 1 degree.
Old May 14, 2007 | 09:41 AM
BlackBoosted2's Avatar
BlackBoosted2
Sounds normal to me, my Mini Cooper does 2 degrees at a time, but still works well
Old May 14, 2007 | 10:01 PM
bondo man's Avatar
bondo man
4th Gear
Well that was my first post and I don't think that I explained my problem very well.If the temp is 70 and I turn the temp **** to the right one click it will go to 71.Now if I turn it another click it will go back to 70.If I turn it again it goes back to 71.Now if I wait 5 or 6 seconds I can then turn it again and it will go to 72.It also works the same way in lowering the temp.
Is this right?
bondo man
Old May 15, 2007 | 08:33 AM
MY03Vette's Avatar
MY03Vette
Doesn't sound right at all to me. When I turn the **** it will increase the temp until I stop. Might be something wrong with your controller.
Old May 15, 2007 | 11:16 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. My '99 has no problem running the temp setting up or down as I wish and there are no stop points or limitations of the setting other than the maximum high or low setpoints.
Old May 15, 2007 | 02:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On my 02 z06, the first click just brings the temp display up. Then any more clicks, will raise or lower the values one degree per click. Once the first click is one, I can use my finger and ramp the temp UP or DOWN just about as fast as i can turn it.
Old May 15, 2007 | 08:26 PM
bondo man's Avatar
bondo man
4th Gear
Well does anyone have an idea where to look for this problem?
Thanks bondo man.
Old May 16, 2007 | 10:16 AM
dgrant3830's Avatar
dgrant3830
First guess it that its the head unit itself and they can be acquired on Ebay real easy. It might send this information to the BCM as well, but since my manuals are lost in my garage somewhere due to a move over a year ago, I can't look it up for you. The alternative is to take it to the dealer and have them connect a Tech 2 and find out, but will cost you about $80 to find out where the problem is.
Old May 16, 2007 | 12:18 PM
FRC Jon's Avatar
FRC Jon
Thats weird man
FRC Jon's Avatar
FRC Jon
Thats weird man
Old May 16, 2007 | 04:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks bondo man.
If I were you,, I would break it open and see if you can find any loose solder joints or loose wires. It relatively simple and theres a post on it somewhere!
BC
Old May 16, 2007 | 06:22 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Originally Posted by FRC Jon
Thats weird man
That's nuckin' futs
Old May 16, 2007 | 07:34 PM
bondo man's Avatar
bondo man
4th Gear
Thanks everyone,I will pull the head apart .and look inside and see what I see.
Thanks bondo man
Old May 16, 2007 | 09:59 PM
jdmvette's Avatar
jdmvette
Night Owl for life
you can also get it professionally repaired by guys on ebay good as new.
To Setting dual climate control?
