help me with these 02 sensor codes...
Old May 13, 2007 | 11:42 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Default help me with these 02 sensor codes...
i don't know what happen, but just out of the blue, i started getting these codes:
P0133 HO2S Slow Response Bank 1 Sensor 1
P0153 HO2S Slow Response Bank 2 Sensor 1
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0135 HO2S Heater Performance Bank 1 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P1133 HO2S Insufficient Switching Bank 1 Sensor 1
P1153 HO2S Insufficient Switching Bank 2 Sensor 1
any ideas guys, i need to solve this soon,as im running the car at the track next week, a full days worth of road racing is going to tear up this motor if the 02's are not working... any help is appreciated!!!
Aj
Old May 14, 2007 | 07:27 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Ttt...
Old May 14, 2007 | 07:34 AM
Mr. Jones's Avatar
Mr. Jones
check the fuse for the o2 heaters
located in the fuse box next to the battery.
I think its a 15a, reset the computer
Old May 14, 2007 | 09:28 AM
95BlueBomber's Avatar
95BlueBomber
Aj
I could be way off here but in open loop the 02's are not going to be doing anything. They should zero out when you go WOT. If these codes are popping up at the track I would not worry about it. As far as driveability, it could and should affect that. If you have HPtuners or some type of scanner, do a scan and check the LTFT's.
Old May 14, 2007 | 04:24 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
thanks guys
Mr. Jones, i'll check the fuse tonight!
95BlueBomber: its during normal street driving that the CEL goes off. i haven't gone to the track yet. im going to DRM tommorow so they can scan and see whats up.. thanks for ur insight!
Aj
Old May 14, 2007 | 04:30 PM
95BlueBomber
thanks guys
Aj
Tell the guys at DRM I said hey, they will be able to help you with this issue! I have seen this exact problem before, it actually just happened to my 98 and I erased the codes and it hasnt come back. Hope you get it straightened out!
Old May 14, 2007 | 10:18 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
and we have a winner here!! the fuse was completely blown!!!
thanks Mr. Jones!
Aj
Old May 14, 2007 | 11:59 PM
Hitechzo6's Avatar
Hitechzo6
What race are you going to?
Brian
To help me with these 02 sensor codes...
