ABSfixer C1214
Old May 22, 2007 | 08:42 PM
ptiller's Avatar
ptiller
Default ABSfixer C1214
I just got my EBCM back from ABSFIXER.COM and just finished the install.
Turned the key and NO MORE CODES! I have ABS, Traction control and Active handling back for $158!
I will admit getting the EBCM out was a challenge, especially all 6 screws and both connectors. Helps to remove the air bridge and to have a second set of hands to hold things out of the way. It was easier going back in than coming out.
Old May 23, 2007 | 01:05 AM
Drumbum675's Avatar
Drumbum675
Me too.....
20 min to get it out....15 min to put it back in......
Old May 23, 2007 | 07:26 PM
2001PewterCoupe's Avatar
2001PewterCoupe
3 Cheers to Brandon!!!
Old May 23, 2007 | 08:26 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
I'll be doing mine real soon. I dread getting in that area everytime. It never fails that something seems to break. Glad to hear that all worked out.
Old May 23, 2007 | 08:45 PM
RGAZ's Avatar
RGAZ
Default Ebcm
That is a great price. Any idea what fails and what they repair?
Old May 24, 2007 | 03:54 AM
fdxpilot's Avatar
fdxpilot
Try this thread. It's about 18 pages about the problem, the causes, and the cures. http://forums.corvetteforum.com/show....php?t=1387486
Old May 24, 2007 | 01:34 PM
ptiller's Avatar
ptiller
I think it is a transistor or similiar. Big trick is getting the unit resealed for life in the engine bay.
I did the door module fix with the relay replacement ( ) and I need to do the cold solder joint fix for the dimming HVAC controller. These are much easier, since the units are in-cab.
You would wish that Delphi would have done this right the first time.
Hats off to Brandon.
To ABSfixer C1214
