Zip Tie Mod
Old May 25, 2007 | 06:32 PM
NightmareZ06's Avatar
NightmareZ06
Originally Posted by NocarbutaVetteforme
Well the difference is that you have a 2002 Z06 which came with a better breathing air box than the 97's. The 97 on up to about 2001 had the solid breather box. Air had to get in through the sides, which was hot air at that. SO in your case you wouldn't feel the effect that the rest of us have.
Well, heres where im coming from.....my best friend has a 99 pewter c5 and of course the first mod that he did was put an air intake on it because its cheap and it does provide better airflow. There is NOOO way that you could feel the difference in that car afterwards. It sounded a little throatyer when you got into it but there was no feelable power increase, and personally, not to bash any of you guys that do think you feel something, but u just want to believe that it did soo much for your car that you think it feels like it has more torque or horsepower.Its all in your head IMO.......but to the man who started this thread. yea go with the ziptie mod because it cost nothing and it will help...a bit.....
Old May 25, 2007 | 06:40 PM
Classy97's Avatar
Classy97
Track results.
Dropped from a 13.90-14.0 to a 13.7-13.75.
Well worth the 15 minutes for the zip tie mod.
Old May 25, 2007 | 06:48 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Originally Posted by Classy97
Track results.
You just held your foot in it longer because it sounds cooler now.
Seriously, did you look at the part that you took off? Your car was breathing through 4 holes in the sides about the size of a quarter each, that's it! On the 01's and up they put a small scoop on the front (see above post) and they opened up the sides completely. Of course, the Z got the same treatment just with a larger scoop on the front (also see above).
Old May 25, 2007 | 06:53 PM
Classy97's Avatar
Classy97
I think the K&N came into its own and was able to breathe better. Not to mention I love the sound.
I also drove it like I stole it.
Old May 25, 2007 | 08:02 PM
99C5JA1's Avatar
99C5JA1
No I am coming from the fact that the tires broke loose easier, throttle response was snappier and I did better at the track. I'm very skeptical when it comes to mods. This one works. Do a search on zip tie to see more people with similar results.
Old May 26, 2007 | 01:46 AM
lordbones's Avatar
lordbones
My mod was more cosmetic than anything. I wanted to try something different since I will be scrapping it for a real cold air intake before too long. As far as feeling a difference, none...I was kinda bummed that I felt nothing but, I did however "hear" a difference that's about it...
Old May 26, 2007 | 05:17 AM
David426's Avatar
David426
Zip tie with K&N gave me 10 hp at the rear wheels.. Did a before and after dyno. The stock air box is a major joke... Try running down the street as fast as you can with one finger up one of your nostrils... You get the idea.. Not sure what Nightmare Zo6 is talking about or coming from.. The mod is good fo 2 tenths of a second... Classy 97's numbers are right on target...
Old May 26, 2007 | 03:03 PM
RB Racing's Avatar
RB Racing
I drilled four 2 1/4" holes in my 2000 lid which more than doubled the air intake area. I plan on drilling holes in the fog light housing to direct cool air towards the airbox next.
Old May 28, 2007 | 11:05 AM
Classy97's Avatar
Classy97
Add a better filter for better performance.
Old May 28, 2007 | 11:15 AM
'VETTE PHASE
That's because you have a '01+. It comes with a much better breathing system. The '00 and older breathed through 4 holes about the size of a quarter.
Old May 28, 2007 | 12:13 PM
RB Racing's Avatar
RB Racing
With what a K&N? This filter performs just fine.
Old May 28, 2007 | 05:55 PM
Classy97's Avatar
Classy97
I was refering to the pic. above. It looks like a stock paper filter. If it is an aftermarket please excuse me if I'm wrong.
To maximize performance on the zip tie mod you do not need a paper filter.
Old May 28, 2007 | 07:01 PM
  #33
RB Racing's Avatar
RB Racing
That's fine. It's actually a foam filter made by a German company that specializes in performance air filters, uses three different layers of foam. Thought I would give it a try.
Old May 28, 2007 | 09:24 PM
  #34
Classy97's Avatar
Classy97
How do you like it?
Old May 28, 2007 | 09:56 PM
  #35
RB Racing's Avatar
RB Racing
I haven't had it in that long but it seems to work fine. I did the lid mod at the same time. I have a 2000 which has restrictive inlets so it flows more air now for sure more intake noise also.
Old Sep 20, 2009 | 10:24 PM
  #36
Paul 75 L82's Avatar
Paul 75 L82
Thanks for the link.
Old Nov 9, 2009 | 01:07 PM
  #37
2001_STL_c5's Avatar
2001_STL_c5
Blast from the past I know, sorry guys, but do you have to do the computer reset/relearn thing on this like you do when you get a whole new air intake? or is that just because it relocates the maf? Thanks.
To Zip Tie Mod
Old Nov 9, 2009 | 02:19 PM
  #38
HowlinC5's Avatar
HowlinC5
Thanks for digging this thread up. My '02 coupe runs 13.0's stock. Looks like I could run some 12.9's with the help of some Zip Ties!
Old Nov 10, 2009 | 01:00 AM
  #39
CoreyZ06's Avatar
CoreyZ06
Originally Posted by 02MillenniumVette
If you still have the factory paper filter, you are better off getting an aftermarket airflter. You are not going to see any difference in hp with more air going through a paper airfilter.
false
you are better off keeping your paper filter. your stock engine cant even come close to maxing out the flow potential of the paper filter, and it filters far better than cotton gauze, which is basically a screen not a filter. there is a thread on the flow capabilities and lack of restriction on the similar sized F-body filters somewhere on ls1tech.
"you will only gain 2 hp"
false
goto ls1tech in the vette performance section there is a sticky with before/after ziptie mod dyno results.
if you arent a moron (you're not), you can execute the zip tie mod to perfection, without drilling a bunch of damn holes in anything. that just doesnt look good at all. i mean.. i am comparing having zipties that looks rigged to having a bunch of holes drilled.. but to me the holes are just hideous. if you use larger black zip ties, you dont even notice...
Old Nov 10, 2009 | 01:26 AM
  #40
vette0009's Avatar
vette0009
Default Zip Tie Mod
What exactly is the zip tie mod, and how hard is it?
You can get a VaraRam for $250 Delivered to your door
Bon
