Zip Tie Mod
Old May 23, 2007 | 01:52 PM
Classy97's Avatar
Classy97
Default Zip Tie Mod
What exactly is the zip tie mod, and how hard is it?
Old May 23, 2007 | 02:03 PM
99C5JA1's Avatar
99C5JA1
It involves removing the front portion of the air lid and zip tieing the filter onto the back portion. Very simple.
Old May 23, 2007 | 02:12 PM
rws.1's Avatar
rws.1
This means the whole filter is now exposed to allow more air through.
Old May 23, 2007 | 03:29 PM
Classy97's Avatar
Classy97
Thanks.
It is worth it HP wise and for the track?
Or not enough difference to tell.
Old May 23, 2007 | 03:35 PM
02MillenniumVette's Avatar
02MillenniumVette
If you still have the factory paper filter, you are better off getting an aftermarket airflter. You are not going to see any difference in hp with more air going through a paper airfilter.
Old May 23, 2007 | 03:38 PM
Classy97's Avatar
Classy97
I have a panel K&N does it make any diff. with it.
Old May 23, 2007 | 04:39 PM
99C5JA1's Avatar
99C5JA1
It should make a noticeable difference. Well worth the effort.
Old May 23, 2007 | 08:35 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Take off the shroud covering your airfilter and then ask yourself that question again. Once you see the little area these things are getting air from you won't hesitate to remove the thing and do one of three things.
1. either modify the cover you have or buy a C5Z06 type.
2. Or get a totally new one with a different kind of filter.
3. do the Zip-tie mod
Old May 23, 2007 | 10:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Make sure you do the hood seal, so water does not get sucked into the filter. It has happened.
I did the Z06 air box.
You could also do the swiss cheese mod.
Old May 23, 2007 | 10:02 PM
superjet701k's Avatar
superjet701k
go vararam and never turn back. wicked happy
Old May 23, 2007 | 11:18 PM
Corvette Monkey's Avatar
Corvette Monkey
I like the zip-tie approach.
Tests show that paper filters filter the best:
http://www.bobistheoilguy.com/airfilter/airtest3.htm
And you don't have to be careful of puddles.
Of course, I'm also of the opinion that a C5 is stupid fast even with the stock airbox.
Old May 24, 2007 | 12:10 PM
RB Racing's Avatar
RB Racing
I'm not a fan of the zip tie mod like mentioned above just bore four larger holes in the front cover which will allow more air than the engine will need anyway.
This way the cover will still hold your filter in place.
Old May 24, 2007 | 01:31 PM
KingTut's Avatar
KingTut
Default Swiss Cheese or 1/2 Cheese
I did the half swiss cheese - it is quite effective and is not visable from an open hood view without really straining to look for is - and of course it is FREE!!!!
This is I think a Z06 air box - half drilled
This is an older air box full drilled
Old May 24, 2007 | 01:34 PM
dndrsn's Avatar
dndrsn
FLIP IT!
Old May 24, 2007 | 04:51 PM
NightmareZ06's Avatar
NightmareZ06
Noticeable difference??? Believe me, you wont feel any more power. You may gain 1 or 2 H/p at most!!!
Old May 24, 2007 | 05:11 PM
99C5JA1's Avatar
99C5JA1
When changing to the Blackwing vs. the stock airbox it was indeed a noticeable difference. It wasn't simply a placebo effect. How much power it added I have no idea as I certainly wasn't interested in dyno'ing the car with just a filter change. I'm sure that each manufacturers claims of xxrwhp are probably exaggerated, but at least in my case it made a tangible difference. I don't see why a zip tie'd filter wouldn't help some as well.
Old May 24, 2007 | 05:22 PM
BanditDude's Avatar
BanditDude
Originally Posted by dndrsn
I would've done this, had I seen it before I installed my Vararam.
To Zip Tie Mod
Old May 24, 2007 | 06:40 PM
NocarbutaVetteforme
Well the difference is that you have a 2002 Z06 which came with a better breathing air box than the 97's. The 97 on up to about 2001 had the solid breather box. Air had to get in through the sides, which was hot air at that. SO in your case you wouldn't feel the effect that the rest of us have.
Old May 24, 2007 | 07:44 PM
RGAZ's Avatar
RGAZ
Default Vararam
Get a vararam.
Be done with it.
Best single investment I made for my car so far
Rg
AZ
Old May 25, 2007 | 03:17 PM
lordbones's Avatar
lordbones
Here's what I did...I had a lot of fun with it since it was my first "mod"
http://forums.corvetteforum.com/show....php?t=1646559
Definitely get the hood seal if you cut your box lid!
