Crazy Headlight Issue....
Old May 24, 2007 | 11:58 PM
nikolai's Avatar
nikolai
Default Crazy Headlight Issue....
When I came home tonight and shut my headlights off, they went down but then the driver's side one came up again halfway?!
So I manually turned it down, turned the lights on, then back off again and it did the same thing
Does anyone know what may be causing it to come back up again like this?
Old May 25, 2007 | 12:48 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
sounds like a short cause by hot power wire rubbing against the wire that turns on the headlights. Does your light come on when the ousing goes up?
Old May 25, 2007 | 04:06 AM
DeeGee's Avatar
DeeGee
Theres a TSB out to fix that problem.
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition: Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Old May 25, 2007 | 09:26 AM
nikolai's Avatar
nikolai
Thanks alot for the helpful responses I will certainly get to that fix this weekend.
The light does not come on when the housing goes up.
Old May 25, 2007 | 10:30 AM
DeeGee's Avatar
DeeGee
Always good if a few washers fix a problem
Mind you with Corvette tax they are probably $20 each
Old May 25, 2007 | 05:30 PM
nikolai's Avatar
nikolai
Yeah I was expecting that too....not that bad though, about $25 for all the parts....of course I have to wait until next Thursday to get them because they are not in stock anywhere in my area. Oh well....
Thanks again though
Old May 25, 2007 | 05:54 PM
corvettedoug's Avatar
corvettedoug
Correction
Important
Parts Information
11505463 Washer 3
I had this exact same problem with my car. I replaced just the insulator, thinking hey the first way lasted this long, the new one should as well. The light worked for a few months, then I had the exact same problem. After that I added the washers and insulator and no problems since. The fix is easy and cheap, so do both the first time!
Old May 25, 2007 | 11:32 PM
nikolai's Avatar
nikolai
Wonderful! Glad to hear it, I will be doing this soon, Thanks.
Old May 26, 2007 | 03:12 PM
corvettedoug
Thanks again though
I was able to replace one of the insulators for under $5(only one was bad) and then just went to Home Depot and paid 25 cents for all three washers
To Crazy Headlight Issue....
