Changing shocks...need alignment?
Old May 25, 2007 | 02:18 PM
iceman2430's Avatar
iceman2430
Default Changing shocks...need alignment?
I know on previous cars with struts or when i changed springs that i needed to get an alignment...but with the C5 and it being shock only, no change in height or spring would i need to get one?
Old May 25, 2007 | 03:06 PM
kevin40zx's Avatar
kevin40zx
Most guys on here say no. Makes sense because the spring dictates the ride hight, not the shock. I didn't get an allignment when I did mine.
Old May 25, 2007 | 03:40 PM
94legaleagle's Avatar
94legaleagle
No alignment needed when changing shocks or when changing sway bars - simply drive it around the block once or two times to get the suspension to settle and you are good to go
Old May 25, 2007 | 04:07 PM
jbauch357's Avatar
jbauch357
Some people have seen ride height differences when going to a different shock/sway bar setup. It doesn't make sense to me since they just dampen the suspension, not actually control ride height - but it happens...
If you have never had the car aligned drive it for a couple weeks to let everything settle and then get it aligned...
Old May 25, 2007 | 04:29 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
If never aligned then have it done afterwards. If you have had it aligned then dont worry about it.
Old May 25, 2007 | 06:49 PM
BATM4N's Avatar
BATM4N
My shocks and sways were changed two weeks ago by the help of a Forum member. I had the alignment done 5 months prior and I haven't felt any noticeable difference
Old May 25, 2007 | 08:32 PM
RGAZ's Avatar
RGAZ
Default Alignment
Not required with just shock change.
Rgds,
RG
AZ
Old May 26, 2007 | 09:33 AM
iceman2430's Avatar
iceman2430
Thanks for all the info! i didn't think so but wanted to make sure!
To Changing shocks...need alignment?
