Leaf spring install tips
Old May 30, 2007 | 10:45 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Default Leaf spring install tips
(Posted here and Autocross/Roadrace section for exposure)
I'm going to replace my stock springs tomorrow and will be using the instructions found at LS1Tech. If you have any additional cautions, tips or suggestions please post here.
Thanks,
-RR
Old May 31, 2007 | 07:03 AM
WKMCD's Avatar
WKMCD
Arthur, what springs are you putting in? I've got a set of Z06 in the garage to put on now.
Old May 31, 2007 | 08:41 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Hey Kevin,
I'm installing Hyperco springs. Specs are:
Rear - 777 lbs
Front - 571 lbs
They should be a perfect match with my Koni FSDs.
-RR
Old May 31, 2007 | 09:15 AM
FRCTony's Avatar
FRCTony
Originally Posted by roushraven
Hey Kevin,
Rear - 777 lbs
Front - 571 lbs
-RR
Thats a whole lotta spring there. Please let us know how it works out.
Old May 31, 2007 | 09:43 AM
C5 ChemE's Avatar
C5 ChemE
Thanks,
-RR
You have a link for the instructions?
Old May 31, 2007 | 09:46 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Here ye gowith...http://ls1howto.com/index.php?article=20
-RR
Old May 31, 2007 | 10:26 AM
springpeddler's Avatar
springpeddler
Default Hyperco Installation
Go to www.hypercoils.com , and you will find a link to detailed instrustructions posted on the site.
Dan Kellermeyer helped us with the project, we even used his car for the photo shoot.
Tom Henricks
Hyperco
Old May 31, 2007 | 12:26 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Tom Henricks
Hyperco
Cool, thanks.
Old May 31, 2007 | 06:16 PM
BanditDude's Avatar
BanditDude
You may want to adjust the front spring adjusters in as much as possible and it will help you slide the spring out. I had a brutal workout removing mine...but it was the base spring (more arch). Other than that, you'll be fine.
Old May 31, 2007 | 07:40 PM
bcseitz's Avatar
bcseitz
Like the others mentioned here, LS1howto's instructions made life easier. Pretty easy job. Especially the rear spring.
Old May 31, 2007 | 08:24 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
I finished the install and it was very easy and straightforward. One tip I will add is to put some anti-seize on the threads of the front ride height adjusters. My stock ones are still imovable and may require some vise grip action to get them to turn. Anyway, I haven't driven the car yet because of the pending T-Storms in my area so a review will come later. Also, while I was at it I changed the brake pads to Hawk HPS and did some more undercarriage cleaning.
Here's some weight info for those who may care.
Rear OEM springs - 12 lbs
Rear Hypercoil springs - 12 lbs
Front OEM springs - 9 lbs
Rear Hypercoil springs - 10 lbs
Pictures below show the difference in the curvature of the OEM vs the aftermarket.
Enjoy!
-RR
Front leaf spring comparisons
Rear leaf spring comparisons
Old Jun 1, 2007 | 03:44 PM
springpeddler
Thanks for the report on your install, glad the anti-sieze instruction we have in our install helped. And thanks for the pics!
Tom Henricks
Hyperco
Old Jun 1, 2007 | 04:24 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Tom Henricks
Hyperco
No problem Tom, however I must confess that I could not find the install intructions on your site. I came up with the anti-seize after seeing what happened to my stock adjusters. Definitely a great idea though. By the way, these springs and the Koni FSDs are the perfect combination. I'm posting a review in the general forum section now. Edit: http://forums.corvetteforum.com/show...post1560489288
-RR
Old Jun 1, 2007 | 06:04 PM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Hey Kevin,
Rear - 777 lbs
Front - 571 lbs
-RR
If it's not too expensive I may look into the same setup. The roads here suck!
Old Jun 1, 2007 | 06:56 PM
WKMCD's Avatar
WKMCD
Thanks Arthur. I think I'll do mine tomorrow.
Old Jun 2, 2007 | 12:17 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Honestly it was one of the least stressful mod projects that I've completed. Give me a call if you need any tips but it's really straightforward.
-RR
Old Jun 2, 2007 | 12:00 PM
WKMCD's Avatar
WKMCD
-RR
Very simple. Got them on this morning. Total time 2.5 hours.
Thanks Arthur!
Old Jun 3, 2007 | 10:52 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
then came the rain !
To Leaf spring install tips
