Normal oil pressure?
Old May 31, 2007 | 08:16 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Normal oil pressure?
My oil pressure is reading about 40psi under medium throttle and 33-35 when cruising. Is this about normal? Did a search and could not find any numbers. Thanks
Cajun
Old May 31, 2007 | 08:25 PM
65GGvert's Avatar
65GGvert
Yes it is.
Old May 31, 2007 | 08:26 PM
0Cajun @ Edgyvette
Former Vendor
Originally Posted by 65GGvert
Yes it is.
Thank you, I appreciate you taking the time to reply.
Cajun
Old Jun 1, 2007 | 12:21 AM
rws.1's Avatar
rws.1
that is about where my reading is now that I replaced my old maxed out sensor
Old Jun 1, 2007 | 12:34 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here check this out, these are the very minimal pressures you can run if your above these then your good to go!
1.18) What should my oil pressures be?
With 5W-30 Mobil 1, the 2000 manual lists hot oil minimum specs at:
6 psi at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
So, if you are above those numbers, you are still just fine.
Oil filter you use can have an effect on presures somewhat - Mobil 1 filters are known to reduce pressure a bit versus the GM factory PF44 and PF46 filters.
Thanks,Matt
Old Jun 1, 2007 | 08:19 AM
0Cajun @ Edgyvette
Former Vendor
Thanks,Matt
Good stuff, I am definitely there.
Old Jun 24, 2007 | 01:14 PM
Bigfoot99's Avatar
Bigfoot99
Man I love being able to search this forum.
I was worried a bit.
Idle I'm a shade over 20psi
1500rpm about 35-38psi
WOT she's 60ish
K&N filter
Old Jun 24, 2007 | 01:20 PM
Oldvetter's Avatar
Oldvetter
Although your pressures are good, I found WIX or NAPA Gold (same filter) oil filters to increase oil flow and pressure over Mobil 1 and DELCO Premium (UPF) filters. I switched to them.
Old Jun 24, 2007 | 03:48 PM
mtm87tx's Avatar
mtm87tx
im seeing 80psi plus at medium throttle and as much as 95 psi at WOT, i have a mellings oil pump though
Old Jun 24, 2007 | 05:21 PM
BATM4N's Avatar
BATM4N
I have a Napa Gold on right now and getting little higher numbers at cruise and idle than did with the GM pf 44
Old Jun 24, 2007 | 08:33 PM
VETTING's Avatar
VETTING
Been using Wix for years!
Old Jun 24, 2007 | 08:56 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Great info! Think I will be using Napa filters from now on.
Old Jun 24, 2007 | 09:04 PM
Secret237's Avatar
Secret237
I use thier Gold filters, not the Silver.
Old Jun 24, 2007 | 09:09 PM
Blown-Interceptor
What filter number are you using?
To Normal oil pressure?
