Final Intake Debate
Old Jun 20, 2007 | 08:17 PM
ixl4's Avatar
ixl4
Default Final Intake Debate
Ok. I tried Installing the Vararam and after I was done, I was completely dissatisfied with the fit and finish, so I happily took it off and put it up for sale. What else is good out there without the trouble and horryfying finish?
Old Jun 20, 2007 | 08:41 PM
vettenuts's Avatar
vettenuts
I went from the Vararan to the Callaway Honker and am happy with it. I liked the Vararam as well, but the filter was kind of small and with the pollen we get around here I wanted something a little larger.
spiral04's Avatar
spiral04
I'm not sure about others, but the blackwing I have is a piece of cake!
Old Jun 20, 2007 | 08:55 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Blackwing
Blackwing is the one and I only had to cut the vent tubing. That is the way to go as I can convert back to stock in less time that it takes to drink two Heffiewizens. Happy Trails.
Old Jun 20, 2007 | 08:59 PM
JohnnyB's Avatar
JohnnyB
Happy Blackwing user here
Old Jun 20, 2007 | 10:42 PM
Dave68's Avatar
Dave68
If cost is no object, get the Callaway Honker. It relocates the MAF to just in front of the throttle body - exactly where GM placed it in the C6s. If you want a great bang for the buck, check out the Halltech Stinger or SSM. Both come with a larger than stock airbridge and a smooth TB coupler. However, you should get cold air to either one (or the Blackwing, for that matter) to avoid losing 10 HP under high-heat conditions. There are at least a couple of ways to do this:
1. Open up the fog light panels (cold air mixes with hot engine bay air) or
2. Open up the lower radiator cover and use a scoop to blast cold air directly at the filter. See my sig for a link to the procedures.
Old Jun 20, 2007 | 11:57 PM
Chuck01's Avatar
Chuck01
Default Put it back on.
Put it back on, best intake out there....... I have had mine for several years no problems...... did you drive it after your install? Takes a few miles for car to adjust to more airflow...
Old Jun 21, 2007 | 12:28 AM
C5UL8R's Avatar
C5UL8R
who cares about fit and finish it works nobody is gonna see it unless you show it, i mean no offense but it is a performance product!
Old Jun 21, 2007 | 01:45 AM
SLPRC5's Avatar
SLPRC5
hooked my Blackwing up to a Halltech air bridge and cut out the back of the fog lights for more air flow.
Old Jun 21, 2007 | 01:49 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I switch from the vararam to the Callaway Honker and would recommend you do the same
Old Jun 21, 2007 | 02:49 AM
C5UL8R's Avatar
C5UL8R
do you have a performance number differerence numbers? 1/4 times etc...
Old Jun 21, 2007 | 02:56 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Halltech Stinger always and forever. With the cold air screens I installed from WCC you can't go wrong with the setup.
Old Jun 21, 2007 | 03:22 AM
jdmvette's Avatar
jdmvette
Night Owl for life
as you can see, the honker comes highly recommended.
Old Jun 21, 2007 | 07:19 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
No cutting of vent tube.
Old Jun 21, 2007 | 07:28 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
went from stock to z06 airbox to blackwing to Honker.
1/4 mile time differences between z06 airbox and Blackwing were non-existent in my completely unscientific testing. Have not yet run w/ Honker.
Old Jun 21, 2007 | 07:40 AM
dndrsn's Avatar
dndrsn
From Stock to Vararam to "FLIP-IT".
Old Jun 21, 2007 | 08:40 AM
EV2DEMON's Avatar
EV2DEMON
You can also buy a K&N conical air filter that works exactly like a Blackwing for $45 and save yourself the ridiculous Vette tax they get for the 'wing. I don't remember the part number off hand, but I can look it up later if anyone is interested.
To Final Intake Debate
Old Jun 21, 2007 | 09:32 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
No intake, that I know of, has produced the proven times at the track that the Vararam has. I have had every intake on the market, some of them twice and have always come back to the VR. On the latest C5 I did not mess around, went with the vararam first time.
On my last C5 I went from 11.81@116 with a Halltech TRAP to 11.68@119 with no other mods on a cam only car. No other intake gives you the gains the VR does IMO. Now it is not a dyno intake so if you dyno race maybe get as stinger and blow the fan on it. Good luck
Cajun
Old Jun 21, 2007 | 09:53 AM
ixl4's Avatar
ixl4
I don't go to the track, I do 99% street driving and 1% cross...
Knowing this, is there really much difference between VR and a Honker?
Old Jun 21, 2007 | 10:29 AM
Humanoid 2.0
I never ran it at the track with the vararam when I had it on, and I had it on for a about year. I ran only with a cat back and with the honker with long tubes and high flow cats. With the cat back I ran just over 14 at about 100 mph (was a hot day). With long tubes and honker I ran consistently 12.7 at about 110 mph on two different days this year and I doubt that is all do the long tubes and cats, the temps were cooler so that helped a bit. Regardless the throttle response is much better throughout the whole rpm range not just the top end, I feel a lot more confident in the sealing around the filter, the varaman got dirty a lot faster, the honker filter is still clean. No lean surging or codes and the honker is emissions compliant on the LS1. It is just better engineered and better quality.
