Air Pump Function????
Old Jun 8, 2007 | 04:54 PM
C5TORCHED's Avatar
C5TORCHED
Default Air Pump Function????
Stupid question but does anyone know about the air pump found in the d/s front? What does it do, can I diconnet it? Will it throw codes if disconnected?
Old Jun 8, 2007 | 05:47 PM
99C5JA1's Avatar
99C5JA1
It will throw a code if disconnected. It's purpose is to inject oxygen into the exhaust right after start up to help burn any leftover fuel in the exhaust during this rich condition.
Old Jun 8, 2007 | 05:50 PM
C5TORCHED's Avatar
C5TORCHED
I read that some of the guys on the forum- do not use them?
Old Jun 8, 2007 | 08:17 PM
ZeeOSix's Avatar
ZeeOSix
It also runs during a self diagnostic test of the air injection system. If anything in the air system is not working right, a code associated with the failed component will pop-up.
Old Jun 8, 2007 | 08:47 PM
Mike Mercury's Avatar
Mike Mercury
Air Pump Function
lets just be honest here... it's "function" is to please dolts like this:
those before him, those that accept him now, and those that take his place in the future.
Same can be said for the C5 "pup cats" real function...
Old Jun 8, 2007 | 10:40 PM
luch90's Avatar
luch90
the purpose of the air pump is to add air during the first few minutes of runtime to your exhaust stream. this coupled with the extra unburned fuel from the warm up enrichment gets the converters up to temperature and operational much faster.
Old Jun 8, 2007 | 10:50 PM
C5TORCHED's Avatar
C5TORCHED
If you put on aftermarket exhaust-- does this get bypassed. What I am saying is can the air pump be eliminted without any problems?
Old Jun 9, 2007 | 03:22 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Most aftermarket headers have the bungs for the AIR system, but it can be removed no problems. I removed mine and sold the stuff in the parts section to pay for other mods. Less weight and less clutter in the engine bay
Old Jun 9, 2007 | 08:38 AM
Oldvetter's Avatar
Oldvetter
It should be noted that if your state does the emissions checking by checking the computer for codes, you will fail !
Old Jun 9, 2007 | 08:44 AM
Vettedreamer2's Avatar
Vettedreamer2
After removal u will need to have the codes turned off in the pcm. This will allow u to pass the computer check. Most states don't (I know CA does) do a visual inspection for this equptment.
HPT has this feature, not sure what other tuning software does, but I think most do
Old Jun 9, 2007 | 08:57 AM
vettenuts's Avatar
vettenuts
I also verifies the operation of the front O2's. With the system in operation, the PCM looks for the extra air reading from the O2's.
Old Jun 9, 2007 | 10:24 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
I deleted mine when installing supercharger ...
My engine bay looks much cleaner
Old Jun 9, 2007 | 10:58 AM
C5TORCHED's Avatar
C5TORCHED
I live in NY and if the check engine light is on it will fail. S0 whatyou guys are saying is that I can delete the air pump a code or check engine light comes on and has to be turned off through the pcm? How do you turn it off?
Old Jun 9, 2007 | 12:08 PM
ryoder's Avatar
ryoder
I removed it from my 82 Camaro when I was 16 and I plan to remove it from my 02 C5 now!
I can't wait to get it out of there. I am not sure of when to do it as I might go turbo or might go supercharger and I don't want to buy headers till then.
Old Jun 9, 2007 | 12:12 PM
FRCTony's Avatar
FRCTony
You have to get the computer reprogrammed to not report an error for the air pump.
Old Jun 9, 2007 | 12:13 PM
FRCTony's Avatar
FRCTony
Actually the O2's verify that the air is being injected.
Old Jun 9, 2007 | 12:50 PM
C5TORCHED's Avatar
C5TORCHED
What type of computer can be used to reprogram pcm?
To Air Pump Function????
Old Jun 9, 2007 | 12:57 PM
99C5JA1's Avatar
99C5JA1
Any laptop with HPTuners or LS1Edit.
Old Jun 9, 2007 | 01:38 PM
C5TORCHED's Avatar
C5TORCHED
Is this something a regular shop has? After cleared, no codes should show?
Old Jun 9, 2007 | 05:15 PM
C5TORCHED's Avatar
C5TORCHED
anyone?
