throttle control fuse blown
Old Jun 9, 2007 | 11:53 AM
kirkhampf's Avatar
kirkhampf
4th Gear
Default throttle control fuse blown
I was driving in 101 F weather the coolant temp was 220 F and car was running fine (2001 z06). I stopped for an errand and when I restarted the car it ran rough, dashboard said reduced engine power / traction control/ check engine. The gas pedal didn't work and engine idled about 1500 but rough. I limped back home and let the car cool but in the morning the same thing was happening. I checked the forum and cleaned the ground connections also unplugged the battery cleaned contacts. Still didn't fix it.
I checked the fuses and found the throttle control 15 A fuse blown. Replaced it and car runs fine. Has any one had this happen or know if this is a recurrent problem in hot weather.
Old Jun 9, 2007 | 12:12 PM
kirkhampf's Avatar
kirkhampf
4th Gear
Default codes on computer
the codes on the diagnostic are 28tcs - C1225, C1278 and 40bcm - B2597, B2721. Not sure what that means.Any help is appreciated.
Old Jun 9, 2007 | 04:49 PM
DeeGee's Avatar
DeeGee
C1225 RF Excessive Wheel Speed Variation
C1278 TCS Temporarily Inhibited By PCM
B2597 Traction Control System Switch Circuit
B2721 PASS-Key Detection Circuit
None of those look like codes that should blow a fuse
The first 3 are traction control related and shouldn't affect the throttle control as far as I can see
I'd replace the fuse, reset the codes and see how you do. Could be a one off.
Old Jun 9, 2007 | 09:03 PM
kirkhampf's Avatar
kirkhampf
4th Gear
Thanks, seemed odd to me as well. I noticed you're in England..my dad is from Bolton but now lives in Malaysia. Anyway, thanks for the info I'll let you know if it happens again.
Old Jun 10, 2007 | 03:06 AM
DeeGee's Avatar
DeeGee
Bolton Wrong side of the Pennines. I'm a Yorkshireman.
Heres a copy of the codes for future reference:
http://www.stengel.net/diccodes.htm
Hope you don't hit the snag again.
To throttle control fuse blown
