New PCM Installed.
Old Jun 10, 2007 | 07:32 PM
SLPRC5's Avatar
SLPRC5
Default New PCM Installed.
On my 1997 A4, after having a new PCM installed and re-flashed by the dealer with the stock tune, then it was dyno tuned. Afterwards I began to get the message "Service VEHICLE Soon" the code is 1281, the cause is Steering Sensor Uncorrelated Malfunction.
Never had this message before the PCM was replaced.
Tuner thinks it could be a faulty reading caused by the new PCM and will have to be re-flashed to delete it.
Has anyone else have this problem after a new PCM was installed?
Thanks,
SLPRC5
Old Jun 11, 2007 | 01:12 AM
SLPRC5's Avatar
SLPRC5
ttt
Old Jun 11, 2007 | 02:43 AM
Cscokd's Avatar
Cscokd
I recently had to replace my PCM on my '98. I didn't have any issues.
John
Old Jun 11, 2007 | 12:07 PM
SLPRC5's Avatar
SLPRC5
John
Thanks for the input John....I think when the heads were installed they moved the steering rack out of the way to torque the front head bolts and must have moved the steering wheel and now causing the code to come up.
Old Jun 11, 2007 | 12:14 PM
vettenuts's Avatar
vettenuts
Before faulting the new PCM, you may want to verify the steering position. I think there was a procedure for doing that on here somewhere, you might be able to find it with a search. Not sure if it was Bill Curlee who put it together, I just remember seeing it as there have been a few that have run into this after a cam swap (not necessarily a PCM swap).
Old Jun 11, 2007 | 01:29 PM
Billdog350's Avatar
Billdog350
I believe your BCM interfaces with the C1281 (steering sensor).
Check into it. I don't think a PCM would in any way CAUSE a steering sensor issue.
Old Jun 11, 2007 | 01:40 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
This is more than likely the cause, if the rack is disconnected from the steering shaft and the steering wheel is allowed to rotate then you'll get the fault, it will need to be resynched using a tech II. The PCM should have no affect on this.
Old Jun 11, 2007 | 07:49 PM
SLPRC5's Avatar
SLPRC5
Thanks for your input. I found this out today. The installer told me to come and they will fix the problem by disconnection the steering shaft and rotating the steering wheel 180* and that will fix the problem.
Old Jun 11, 2007 | 08:48 PM
SLPRC5's Avatar
SLPRC5
Yes vettenuts..not that the installer is admitting moving the steering rack out of the way to have clearance in order get to the head bolts up front to torque them, this is what most likely happened. So he told me to bring it in and they will rotate the steering wheel 180* and this will correct it.
I also was told that the voltage reading at the sensor connection should read 2.5 and if lower then go through the procedure of rotating the steering wheel until it reads 2.5 or close to it. Tie the steering wheel down then check the front tires to see if they are straight, if they are not then disconnect the steering shaft bolt and straighten the wheels then tighten the bolt and this will correct the sensor position....
Thanks again for you valuble input...
Old Jun 12, 2007 | 05:34 AM
vettenuts's Avatar
vettenuts
One other note, if the steering wheel is off 180, I would think it would be upside down when driving. Also, I think the airbag wiring has limited movement, so if the steering wheel is off try not to turn the wheel all the way until you correct the situation, I believe it could damage the airbag wiring.
Someone please correct me if I am wrong on this.
Old Jun 12, 2007 | 08:02 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The steering shaft will only connect to the rack one way so when it's disconnected you'll have to rotate it 360 degrees, also the airbag sensor (clock spring) doesn't have any wiring that will get twisted so don't worry about that.
To New PCM Installed.
