hot cockpit
Old Jun 13, 2007 | 06:37 PM
bhard's Avatar
bhard
Default hot cockpit
when running my baby on the capital beltway (MD/VA) my right leg gets alot of heat coming from the console area i guess, is this normal and what can be done about it?
Old Jun 14, 2007 | 12:38 AM
rws.1's Avatar
rws.1
It is normal, but can be solved....
The issue is the cheap thin tunnle plate that comes with the car.
Upgrade to a thicker, coated or insulated tunnel plate.
They dramatically reduce the console temp.
here is a link to the only one I know of that is insulated
http://www.eliteengineeringusa.com/T...emp_Tests.html
CCA also sell tunnel plates
http://www.customcorvetteaccessories...nnelplate.html
Old Jun 14, 2007 | 08:57 AM
DPG's Avatar
DPG
St. Jude Donor '06
crazycowboy also has a insulation kit that is super easy to install.
Old Jun 14, 2007 | 11:26 AM
TSDuke's Avatar
TSDuke
Try pressing the "recirculate inside air" button on your HVAC controls.
Old Jun 14, 2007 | 11:52 AM
Blown-Interceptor's Avatar
Blown-Interceptor
Thanks for the links!
I have been having the same problem.
Old Jun 14, 2007 | 02:28 PM
JEEP/C5's Avatar
JEEP/C5
The easiest and cheapest way is to install Frost King under the consol. Takes 30 min and cost like 5 bucks. I installed FK in front and back and it really made a difference in notice level and heat in side the cabin (esp. in the rear compartments).
Do a search on Frost King and you will see a ton of links and pictures.
The tunnel plates require the the exhaust system to be removed. Most guys wait till they do a cat back exhaust system and replace the tunnel plate at the same time.
Old Jun 14, 2007 | 02:44 PM
lightning30's Avatar
lightning30
Best thing that would help is get a thicker tunnel plate
Old Jun 14, 2007 | 04:05 PM
Last C5's Avatar
Last C5
Ceramic Coated
Old Jun 14, 2007 | 04:43 PM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by Last C5
Ceramic Coated
Ceramic coated plate help me quite a bit.
Old Jun 14, 2007 | 05:22 PM
BanditDude's Avatar
BanditDude
Frost King works very well.
Old Jun 14, 2007 | 05:42 PM
Corvette Don's Avatar
Corvette Don
Dam I should have done that to mine when I had it out, even with no cats now it gets hot
Old Jun 15, 2007 | 01:05 AM
Z06ster's Avatar
Z06ster
Yep, that's what I did. I had an Elite Engineering tunnel plate installed when I did headers/X-pipe/mid-pipe installation,
As for keeping things cool, now that we're approaching summer here in Southern California and it is getting 90 degrees mid-day, I have noticed a big difference.
Old Jun 15, 2007 | 01:55 AM
NOS500's Avatar
NOS500
It gets hot for me in my c5, not enough to bother me, but in my dads c6 its even worse down by your lower leg.
To hot cockpit
