Correct preload for an LS1?
Old Jun 13, 2007 | 11:23 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Correct preload for an LS1?
who knows what the suggested or even stock preload of an LS1?
Old Jun 14, 2007 | 04:29 AM
Third Gear's Avatar
Third Gear
Installing the rockers right? If they're adjustable you want to get to top dead center on that cylinder and then get to zero lash (push rod becomes difficult to turn with fingers) - meaning no slack in the system, yet no preload. Then you want to go an additional 1/4 to 1/2 a turn and you're done.
The stockers, or non-adjustable ones just require a torque down to 22 lb/ft. (My Yella Terras said 25 lb/ft) The manual has a special procedure that you can follow after adjusting both intake and exhaust on cylinder 1 (stock cam). I can give it to you if you need it. For an aftermarket cam I feel safer just getting each individual cylinder to approximately TDC then torquing... I just think compressing a valve spring will skew the torque readings.
Old Jun 14, 2007 | 05:31 PM
N0TDADYS_98
I've already replaced my cam and used 7.400's. This is the standard size that TSP sells. It was what they suggested at the time of sale.
the cam is a 228R btw. I didn't think anything more about it. THe install went fine and got it tuned... valve train is kinda load but i'm told that was normal.
My buddy just did a cam swap and put down some really low numbers for hsi cam. Torquer V2. from TSP. Used the same 7.400 rods in his. Put down 360 with all the supporting mods. This is the exact same dyno i put down over 380 with my cam. So we started looking around and found that his preload is really high. Can't remember the exact number but i think it was in the low 90's.
after watching this i got curious and popped the valve covers off mine and measured a preload of 66. I've done alot of research online to find out what the idel preload is and i can't find a common answer.
one of my buddies who's been building engines for years said the magic number is usually around 30. i've found numbers ranging from 30-90. to me that variation is huge. TSP suggested 40-60. in that case i'm outside their suggestion and on the high end. So before i go buy another set of rods i want to clarify what the correct preload is.
Old Jun 14, 2007 | 05:47 PM
voda1's Avatar
voda1
.080 for stock lifter, .060 for Cadi lifter
Old Jun 14, 2007 | 05:48 PM
N0TDADYS_98
So then i need longer roads instead of shorter ones????
Old Jun 14, 2007 | 06:30 PM
vettenuts's Avatar
vettenuts
I measured just under 0.100" with the stock setup. With the adjustables, I ran 0.125" as recommended by Crane. No issues.
Old Jun 14, 2007 | 07:10 PM
N0TDADYS_98
crane recommends 50-80
http://www.cranecams.com/?show=newsLetters&no=112
Old Jun 14, 2007 | 07:20 PM
vettenuts's Avatar
vettenuts
Originally Posted by N0TDADYS_98
They have contradictory preloads.
Rocker Adjustment
The rocker procedure calls for 1-1/2 to 1-3/4 turns plus 1/8 turn lock-down. With 1.8 rockers, us 1-7/8 final location this comes out to 0.120" of lifter pre-load based on a 3/8-16 thread.
Old Jun 14, 2007 | 11:10 PM
N0TDADYS_98
contradictory preloads is all i seem to find... I dont' understand how there can be so many "standards" or "correct answers" to what should be a pretty cut and dry answer.
I'm honestly starting to believe no one knows the answer and it's kinda a grey area.... 8 years ago i could understand there still being questions but dangit my car is almost a decade old.. heck some C5's are. How is it i keep getting different numbers????
Old Jun 15, 2007 | 03:20 AM
Third Gear's Avatar
Third Gear
Ah, I see you were talking in like.... thousandths of an inch. Yeah, in that case I don't know. I agree, there's no real "truth" to setting the preload. I've seen so many different ways to put on rockers it's downright confusing. It seems most people throw 'em on and if it works... they stick with it. I'll see how mine runs very soon... I ordered +0.025" by the cam grinder's recommendation.... and I have Yella Terra non-adjustables. I had to use the shims as without them the pedestal wouldn't touch the cylinder head, lol.
Old Jun 15, 2007 | 05:39 AM
vettenuts's Avatar
vettenuts
Best bet, which is what I did, was take your stock setup and use an adjustable pushrod to measure zero lash then compare the length to the stock pushrod to get the difference. If I remember correctly, it was close to 0.100". Some aftermarket lifters like a tighter tolerance on the preload, with the Comp R's being the extreme. The Morel's that I run have a plus or minus 0.010" tolerance on preload so I have an adjustable rocker setup (Crane rockers) to get it correct. The other thing to watch for is the pushrod length is "gauge length" not overall length so you can't measure with a vernier accurately.
Old Jun 15, 2007 | 06:16 PM
N0TDADYS_98
thanks for the replies guys. I believe my buddy gets his new rods today. we are going to drop him down to .04ish i don't have hte numbers infront of me. will report back with the difference in performance both at the wheels and the behavor of the valve train... better he take the walk in the dark than me...
I think as mentioned above; If you slam them in and it runs then great leave it be seems to be the way things are done. I would have never thought to investiage this until this happened to him... makes me wonder how many other people that are disappointed in their numbers at teh dyno and track couildn't correct their problem with a simple rod swap....
Old Jun 16, 2007 | 12:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Jun 16, 2007 | 08:36 AM
vettenuts's Avatar
vettenuts
There is some information over on the Vinci High Performance web site, Roger actually found the dyno results were better with the preload set a little deeped if I remember correctly. They recently made some web site updates though and I am having trouble finding things now.
Old Jun 18, 2007 | 07:23 PM
N0TDADYS_98
I'll take a peak at it.. Thanks for your continued input.
To Correct preload for an LS1?
