Hard to get into reverse?
Old Jun 14, 2007 | 11:36 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Hard to get into reverse?
My MN6 has developed a problem with the trans. It's hard to get into reverse. It doesn't matter if the car is running or not.
Sometimes it goes in and other times it won't. 1st - 6th are fine, just reverse. Clutch fluid is fresh and full with no air (I bled it to be sure).
Any ideas?
It's getting an alignment today, so I'll be able to look at it went it gets home.
Bob K.
Old Jun 14, 2007 | 11:52 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
any codes?
the reverse lockout solonoid could be acting up...
Old Jun 14, 2007 | 12:00 PM
hotwheels57's Avatar
hotwheels57
Shifting forks? The shifter mechanism has loosened and needs realignment/adjustment?
Old Jun 14, 2007 | 12:01 PM
sliebl's Avatar
sliebl
Ours is difficult to get into reverse some times, but mostly doesn't like staying in reverse. We've got to hold it in or it can and does pop out.
We changed the ATF in the M6 with Amsoil ATF and it seems to be a little better than before, but that's hard to determine.
Many people swear by Royal Purple ATF for the hard shifting M6 problems. It's not a very costly project. $50 at most if you do it yourself. Can't hurt to try that first.
Old Jun 14, 2007 | 12:12 PM
Bob K's Avatar
Bob K
Default So far.....
Chris,
No codes. I checked them right away.
sliebl,
I've got Royal Purple in there already.
hotwheels57,
You might be on to something. I hope I don't need to swap in the backup trans.
Bob K.
To Hard to get into reverse?
