Differential leaking fluid
Old Jun 14, 2007 | 09:03 PM
fearless's Avatar
fearless
Default Differential leaking fluid
Hey I just got this car monday night from my mom. She has never notice any fluid on the ground. But when we parked the car in the garage I went back outside about 5 hours later and noticed oil underneath it. I jacked up the car and noticed that the rear end was wet on the side of the drivers side rear. It looks like maybe the seal that holds that side on, is bad???? But it also looks like it may be coming from where the trans bolts into the diff.
I have no clue how to even tackle this. Could somebody show me a parts diagram of how this goes together, and how hard is this to do???? How much for new seals?
Old Jun 14, 2007 | 09:07 PM
mi.vette's Avatar
mi.vette
Dude I just posted Oil leaking from rear. I have the exact same issue. I have a 2000 manual. This is odd that you and I both are having the same problem at the same time.
Hope someone here can assist us.
Old Jun 14, 2007 | 09:12 PM
fearless's Avatar
fearless
mine is a 2000 with only 30,000 miles on it. Passenger side rear is dry as a bone, but driver side is wet.
Old Jun 14, 2007 | 09:13 PM
pala's Avatar
pala
St. Jude Donor '07
Default leaking butt
pretty common problem
use search button to find many threads
mine was leaking too, cost $625.00
Old Jun 14, 2007 | 09:16 PM
mi.vette's Avatar
mi.vette
This sucks $625.00. I only have 21000 mile on it. GM should cover this as a known problem.
Old Jun 14, 2007 | 09:18 PM
mi.vette's Avatar
mi.vette
I just got done tonight cleaning under the car in that spot so that tomorrow I can see exactly where it is coming from. But like you said, it is coming from that plate.
Old Jun 14, 2007 | 09:24 PM
Rickyh93's Avatar
Rickyh93
All new seals are about $75-80 from Gene Culley (gmpartshouse.com).
http://www.cajundude.com/outputshaftseal.htm
I will be replacing mine soon also.
Ricky
Old Jun 14, 2007 | 09:34 PM
Point & Shoot's Avatar
Point & Shoot
Had mine done under warranty by the dealer - drivers side too!!
Old Jun 14, 2007 | 09:39 PM
fearless's Avatar
fearless
Is this a common problem on all the vette's??? I thought maybe I did something wrong last time I took the car out. My fiancee says its because I drove it at 120 mph. But I seriously doubt that.
Old Jun 14, 2007 | 09:42 PM
Rickyh93's Avatar
Rickyh93
Some members have mentioned that if the diff was overful some could come out of the vent, but if you can see it leaking on the side then that is pretty common. I can't tell where mine is coming from so I'm replacing all of them, since I will have it out.
Old Jun 14, 2007 | 09:59 PM
mi.vette's Avatar
mi.vette
I just read many many many stories about this problem.
Some are saying it is because of the level of oil.
Some say it is venting due to heat.
Some are saying that you will need the seal replaced. $650 - $1200
Some people have replaced the fluid with something called Red Line.
I have had my car new from 2000 and this is the first time I am seeing this. I only drive it on sunny days and garage it through winter. We have had extremely hot days here in MI. and I have been driving it more then ever this week. I drive it on the expressway where I have had to sitting traffic and work the clutch a lot. Maybe it is from the heat and is venting.
I'm going to watch this and let the car sit a few days until I drive it again and see what it does.
Old Jun 14, 2007 | 10:58 PM
fearless's Avatar
fearless
maybe mine is just venting??? It has been hot here in texas, didn't notice any problems until my fiancee came home from school and then parked it, and came back 5 hours later and had a little puddle under it. Car has been parked for some time with no driving action, so maybe it was just in shock???
Old Jun 16, 2007 | 05:09 PM
Lord Melbury's Avatar
Lord Melbury
Hi,
this is a known issue by GM, see below. I've just done the mod by myself on my -02 coupe, not so difficult but a lot of work:
Rear Axle Side Cover Oil Leak - fluid leak seal repair #PI01363 - (Sep 12, 2003)
Condition/Concern:
The rear axle side covers may exhibit a fluid leak.
Recommendation/Instructions:
When installing the rear axle side cover(s) a new o-ring and axle seal should be installed and a material such as Loctite® 518 should be applied to the outboard side of the o-ring. The sealant should be allowed to set prior to filling the axle with oil and driving.
Part Numbers (Correct as of 9/2/03)
Side Cover O-Ring Seal - 89047953
Axle Seal - 88996703
Loctite 518 - 22423 Flange Sealant 25 ml with primer, 22424 Flange Sealant 300 ml with primer
Models:
(97, 98, 99, 00, 01, 02, 03, 04 Chevrolet Corvette)
Old Jun 16, 2007 | 06:06 PM
ZeeOSix's Avatar
ZeeOSix
Just to let you know, oil can also come out of the differential's vent located at the top/drivers side of the differential. Once and awhile on my Zee, I would notice oil on the floor dripping off of the driver's side of the differential cover ... but if I wiped my finger around the LH seal it was dry.
So I thought it might be the LH cover O-ring (also a common problem). I also found oil residue up near the vent ... and ultimately concluded that the venting oil would run down the gap between the LH side cover and the differential body and drip off the bottom of the LH cover.
It can be very deceiving on where the oil is actually coming from, and suggest you determine exactly where it's coming from before going in for a repair that might not be required.
Old Jun 17, 2007 | 10:42 PM
OldYellow's Avatar
OldYellow
2nd Gear
Default Rear Differential Leak
Okay let me add another car to the list. I have a 2003 Z06. Car has 8100 miles on it. I just purchased the car a few weeks ago. During my pre-purchase inspection I had the car on the rack and there were no leaks anywhere. I drove the car this past weekend for about 30 miles on the interstate. After parking in the garage I noticed the oil spot on the floor. I saw the same type of area leaking - driver's side of the housing. What was interesting is one day later when removing the fill plug to check the oil level I could hear pressure escape when I loosened the plug. Shouldn't the vent remove all pressure on the housing or is it spring loaded to allow some pressure before release? Fill me in guys. I am a new Z06 owner.
Old Jun 17, 2007 | 11:05 PM
Rickyh93's Avatar
Rickyh93
Mine made the same noise when I checked my fluid level. Maybe I will check the vent, that didn't even cross my mind.
Old Jun 17, 2007 | 11:47 PM
ZeeOSix's Avatar
ZeeOSix
The differential vent IS spring loaded with a very weak spring - it's a one-way valve to relieve positive pressure from inside the differential. But it might be possible that could get stuck if the seat somehow clings. I'm not sure what the seat material is, but if it's rubber it might stick after sitting awhile.
Are you sure the differential had pressure or maybe it was under a slight vacuum? – I’ve read a few instances too that it could be under a slight vacuum due to the one-way vent valve and the cooling action of the diff after it's vented while hot. In any case, the vent shouldn't allow much pressure build up before venting.
I checked the vent's function on my Zee by removing the fill plug, then sticking a short piece of Tygon tubing inside the differential. The used some compressed air regulated way down in pressure and carefully blew some air into the diff while feeling around the vent. I could hear and feel the air escape from the vent. Keep in mind that there was also some clearance between the tube and the fill hole, so it would be hard to build up any significant pressure during this test.
To Differential leaking fluid
Old Jun 18, 2007 | 12:45 AM
SpinMonster's Avatar
SpinMonster
Too bad youre in MI. If you were local we could do that in 2 hours and it would cost about 50 bucks with new fluid.
Old Jun 18, 2007 | 06:03 AM
vettenuts's Avatar
vettenuts
While you guys consider what you want to do, one word of advice. If it is leaking and you let it get low you will have much bigger problems as the rear doesn't hold much oil. So at a minimum I would suggest you check the level and if low fill to prevent any damage.
Old Jun 18, 2007 | 10:57 AM
timemender's Avatar
timemender
Just an FYI
The Chevy dealer (Ferris) in New Philadelphia, Ohio replaced the left (drivers) differential axle seal for $300.00 on my 2000. This was repaired last fall (2006) by the previous owner, who is a long time friend. Car had 24,000 miles on the clock at the time.
Last fall I was telling him that my 5,400 mile 2003 Corvette had dampness around the left axle seal and that this is a common C5 problem, regardless of mileage. Upon inspection, he found evidence of a slight leak, so he had the seal replaced. I told him to expect at least $600.00, so he was pleasantly surprised to pay $300.00.
We both have lifts and I offered to help him replace the seal at his house or mine, but he was leaving on a Corvette road trip the following week and didn’t want to tear into it.
