Ive looked in every data base and book that I have and cant find C2120! Try disconnecting the battery for a few minutes and reconnecting it. Then clear all the DTC and see what you get. While you have the terminals off the battery clean them and make sure that you re torque the terminal bolts to 11 FT/LBS.
BC
I found C2120 by doing a thread search on this site. That code was highlighted in red (don't know why).
Since I've had the problem, I've replaced the battery. The "Serv Tire Mon Sys" message still came back. I haven't cleared the codes since then though.
BC
Thanks for checking Bill. I found C2120 by doing a thread search on this site. That code was highlighted in red (don't know why).
I just reset the C2120 code. There was no "serv Tire Mon Sys" message when I started the car. I drove it a few miles - still no message but I'm not getting any pressure readings either. If I recall from before this problem, I'd get pressure readings within a few miles. Not sure what's up now.
FYI, I mounted some aftermarket wheels that did not have sensors, and the message on the DIC was the same "Serv Tire Mon Sys." It still may be the receiver, but the message you're getting doesn't tell you that. The fact that all four stopped registering at the same time seems to point to the receiver.
