what is it??
Old Jun 23, 2007 | 10:33 PM
fisheson's Avatar
fisheson
Default what is it??
okay, after my 98 a/4 car is warmed up and sitting idleing,[at night] a motor/servo/pump/????? underneath the drivers side headlamp, below the frame horn, clicks or cycles. and will make the running lights dim for a split second..., any ideas as to what it is is,and why or what is making it short the electrical system........thanks
Old Jun 23, 2007 | 11:07 PM
Oldvetter's Avatar
Oldvetter
Could be the air pump, it reduces emissions.
Old Jun 24, 2007 | 12:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its the A. I R. ( (Air Reaction Injection ) pump. It injects fresh air into the exhaust manifolds after the engine is warm to test the CATs. The PCM checks the putput of the O2 sensors during the run cycle and expects to see a change during the test.
The pump only runs for a couple of minutes during the test and for the most part its OFF.
BC
Old Jun 24, 2007 | 11:00 PM
fisheson's Avatar
fisheson
thanks for the reply,..is it suppose to have a very large draw on the electrical sysem??. can it be un-plugged??........thanks
Old Jun 25, 2007 | 06:59 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you disable it, it will cause the PCM to throw a DTC. Then it wont pass emissions. You can have it tuned out of the system.
Old Jun 25, 2007 | 10:05 AM
bluvette79's Avatar
bluvette79
i think i would also check the voltage on your battery to make sure it is up to snuff. sometimes a weak battery will not have enough juice to support the initial startup requirement of an accessory like the pump. should have more than 12 volts across the battery, engine off.
Old Jun 25, 2007 | 04:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your concerned on the amount of current draw it is using, install an amp meter in series with the AIR Pump and measure the draw. It cant be all that much or it would blow the fuse.
BC
Old Jun 25, 2007 | 11:39 PM
fisheson's Avatar
fisheson
Default air pump testing
good point on blowing a fuse!......is there a way to test with out using the cars voltage<?? what should it draw for power??
To what is it??
