Is Dexcool cool or not so cool?
Old Jun 24, 2007 | 07:58 PM
Cruz 86's Avatar
Cruz 86
Default Is Dexcool cool or not so cool?
I've had a few people tell me to flush out all the dexcool and replace it with the good old green stuff. They say the dexcool eats up head gaskets. Whats the story?
Old Jun 24, 2007 | 08:00 PM
vettenuts's Avatar
vettenuts
Total BS and they don't know what they are talking about
Old Jun 24, 2007 | 08:48 PM
my6thvette's Avatar
my6thvette
When I drained my radiator, after 5 years, the Dexcool looked like new. No sediment at all. I am a believer.
Old Jun 24, 2007 | 09:02 PM
Secret237's Avatar
Secret237
Good stuff, one less thing to worry about for 5 years.
( Replace the hoses at that time too )
Old Jun 24, 2007 | 09:15 PM
Oldvetter's Avatar
Oldvetter
Grreat stuff, at 5 years mine drained clean. The only problem is when you get air in the system, when there is a leak. If you don't get it fixed, the coolant can turn "muddy".
Old Jun 24, 2007 | 09:17 PM
corvettedoug's Avatar
corvettedoug
It is great as long as you don't get air in the system. If you do it can turn to a mud like substance and cause radiator and other parts to get gunked up. Then you will have an overheating car.
Old Jun 24, 2007 | 10:00 PM
Bill Dearborn's Avatar
Bill Dearborn
Dexcool provides corrosion inhibitors that aren't in the green stuff and since I have never heard of a LS engine having problems with Dexcool I am not willing to risk my engine for a rumor. I just pulled my Ron Davis Racing Radiator out to get speedy dry cleaned out of the fins. It was filled with a 50/50 mixture of Dex and water for 3 years. Outside of radiator was plugged with speedy dry and tire rubber inside was clean. Hoses were in good shape, reservoir was clean and the coolant looked the way it did when I put it in. I refilled with 50/50 mix of Dex and water.
Bill
Old Jun 24, 2007 | 10:05 PM
tah81's Avatar
tah81
There are several states with class action lawsuits against GM for the use of DexCool. It has proven to be a problem with head gasket and other components in earlier cars (starteing in 1996). Their was an effort to make it a Federal class action suit but that was thrown out so now the states are taking action as they see fit. If you search the internet for "dexcool lawsuits", there is plenty to read. Right now the recommendation (at least in Missouri) is not to change out the Dexcool until a decision is made.
Old Jun 24, 2007 | 10:13 PM
B-ras's Avatar
B-ras
AFAIK, the head gasket issues were specific to the V6 (3.8L?) applications like the Grand Prix. If Dexcool were chewing up head gaskets in LSx motors everyone on this forum would know it. As other said, keep air out of its and you're fine. Just changed mine after 6 yrs and it looked like new.
Old Jun 24, 2007 | 11:07 PM
OGC5's Avatar
OGC5
Default Use Coolant that meets GM Spec
Dex-Cool is a GM brand name,Several aftermarket brands meet GM Dexcool specs including Pennzoil,® DEX-COOL™ EXTENDED LIFE ANTIFREEZE AND SUMMER COOLANT. Use any brand that meets GM spec. Orange color denotes a 5 year use and is recommended for Late model Corvettes. Dex cool is Ethelyene Glycol based. Ethelyne Glycol is a Poison.
Propolyene glycol based engine coolant may be used in GM vehicles and will not affect the warranty coverage if it meets GM spec. It is less toxic.
OGC5
Old Jun 25, 2007 | 09:59 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
A good pink goes good with a nice cheese. The green is better with fish and chicken.
Old Jun 25, 2007 | 02:12 PM
flir_man's Avatar
flir_man
Has anyone used Dex-cool in a cast iron engine and a copper radiator? I know my C5 is all aluminum. I think the advantages of Dex-cool is it runs at higher temps.
Thanks,
flir_man
Old Jun 25, 2007 | 02:56 PM
Bill Dearborn
The DexCool has been in my 2003 Tahoe since it was made in December 2002. The heads are aluminum but the block is cast iron. No problems to date. My wife's 99 Saturn is on its second fill of DexCool with no problems.
People can sue about anything and even win sometimes. It doesn't mean they are right or even know what is going on.
Bill
Old Jun 25, 2007 | 05:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Man your a NUT!!! That was a good one!
Bill C
Old Jun 25, 2007 | 06:23 PM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
I drank dexcool once... it tastes sweet.... then it tastes like burning.....
Old Jun 25, 2007 | 08:31 PM
B-ras's Avatar
B-ras
Just drink more...the burning sensation will stop eventually.
Old Jun 25, 2007 | 08:44 PM
robvuk's Avatar
robvuk
Ok, here's my Dexcool story. I had a problem in 2003 with my 1999 GMC Jimmy. The Dexcool turned into a brown paste. I took it in for a routine radiator flush when it was discovered. They flushed the system and refilled. Everything looked fine for about a year when I checked again and found the brown pasty stuff again. I took it in and they wanted to charge me for a new radiator and engine flush. I talked to the area service rep about it and he told them to just do what they had to do to clean it out good and flush the engine good. They took care of it no charge and I haven't had a problem since. My 2000 Vette has exhibited no problems. No one was able to explain to me at that time why it happened to the GMC and not the Vette.
To Is Dexcool cool or not so cool?
Old Jun 25, 2007 | 10:43 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I've heard about the lawsuits... but it always seems to pertain to mid 90's GM V6s. My mother let her original factory coolant in her '99 vert go until last summer! That's 8 years, but only 45k. Came out looking just fine.
I recently helped a buddy do a tune up on his '97 w/ unknown history and his came out looknig nice.
I drain and re-fill mine every 2 ears or so. On my GMC Canyon I'll go the 5 years.
Old Jun 26, 2007 | 11:23 AM
electra's Avatar
electra
I have a friend who worked for a local Chevy store as a service advisor for 30 years and he said the stuff was crap. GM designed it to last 100K miles but in order to do so compromised its primary objective. If you are going to change your coolant every 20 grand or so (which he also recommends) go ahead and use the stuff. I have used Prestone since my 1st oil change (original owner) and my Z still runs cool and strong and it just turned 120K miles. I also change the coolant every fall.
Old Jun 26, 2007 | 12:39 PM
ditty22's Avatar
ditty22
Its good stuff keep it
