Electrical system going crazy ????
Old Jun 25, 2007 | 07:00 PM
-Blue Vette-'s Avatar
-Blue Vette-
Default Electrical system going crazy ????
About a week ago I picked up my vette from the body shop. I had a minor accident and it required some painting. Anyway, every since then I've had some quirky little electrical problems such as...
1) My blinkers wouldn't work at all. They finally started working a couple of hours later.
2) Only one headlamp would pop up the first time I tried to turn them on. After a few cycles up and down, they both came up.
3) The windshield wipers stop in the middle of my windshield when I turn them off (Not good for driving).
I think the body shop may have spray the engine off and got water on a relay or in the fuse box.
Anyone ever have this sort of problem before?
Old Jun 25, 2007 | 10:29 PM
-Blue Vette-
Needen some help here if anyone can provide. My windshield wipers will not return to home position and they're stuck right in front of my view.
Old Jun 25, 2007 | 11:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Brian
What year is your car?
BC
Old Jun 25, 2007 | 11:23 PM
-Blue Vette-
-Blue Vette-
Old Jun 26, 2007 | 12:13 AM
-Blue Vette-
Is there some sort of trick I can try to reset the wiper blade moters? I pulled the the wiper fuse under the passenger side floor. It didn't help.
Old Jun 26, 2007 | 09:23 AM
Billdog350's Avatar
Billdog350
The wipers have a park circuit and also a park mechanism. My 1994 Camaro Z28 had the spring on the park mechanism fail so that the motor cranked backward like it should have, but the wipers would park, and then keep going and stop in the middle of the windshield like you say. Replacing the wiper motor, circuit board, etc didn't solve it. I finally found the broken spring in the mechanism and replaced it with a spring out of a mechanical pencil and it lasted for at least another year until I sold the car.
Old Jun 26, 2007 | 11:23 AM
sjc*2's Avatar
sjc*2
What did they remove for painting. ? Doors.? Panels ?
Old Jun 26, 2007 | 12:47 PM
DeeGee's Avatar
DeeGee
My guess would be either a bad battery or a grounds issue.
Were they running the radio when they were painting and killed the battery?
Autozone will doa free battery load check. Theres a good How To from Bill Curlee out there. Looks like Bill is on the case
Old Jun 26, 2007 | 01:45 PM
-Blue Vette-
Yes, they did drain the battery and they had to recharge it. I started to think that this might be the culprit.
To Electrical system going crazy ????
