Caliper bracket bolt question
Old Jun 25, 2007 | 08:27 PM
radiowaves88's Avatar
radiowaves88
Default Caliper bracket bolt question
Hello, I am replacing the calipers and rotors on my 2002 convertible. I removed the caliper brackets to clean and paint them and noticed that the bolts that attach them had some sort of thread locker on the threads. Does anyone know what locktite I need to use on reassembly? Thanks, Al.
Old Jun 25, 2007 | 08:39 PM
Red903L's Avatar
Red903L
Default RED or BLUE Locktite???
It's been about a year and half ago that I did the same thing, but I think it was the BLUE locktite that I used. I think there are only two choices, either RED or BLUE.
One locks it real tight, the other locks it FOREVER!!!! Just check the labels first.
Good Luck.....
Old Jun 25, 2007 | 08:45 PM
jrprich's Avatar
jrprich
When I pulled mine off the other day it had traces of Red on the threads........so I used red when I put them back together.
Old Jun 25, 2007 | 08:55 PM
vettenuts's Avatar
vettenuts
Service manual actually calls for new bolts that have a locker/sealer on them which is red.
Old Jun 25, 2007 | 11:51 PM
ch3no2's Avatar
ch3no2
Default Red
Red!!!!!
Old Jun 26, 2007 | 12:05 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
New pads, like the hawk hps plus come with red, so I use red on the caliper and pad bracket bolts.
Old Jun 26, 2007 | 01:11 AM
rws.1's Avatar
rws.1
Red on caliper bracket bolts torqued to 125 ft-lbs
Blue on caliper pin bolts torqued to 20 ft-lbs.
Old Jun 26, 2007 | 12:28 PM
bighank's Avatar
bighank
Default Both R Red
Look at new bolts that come with pads. RED, and RED on the large caliper mounting bolts too.
Old Jun 26, 2007 | 02:46 PM
TheDEfan's Avatar
TheDEfan
Use red, Blue is forever
Old Jun 26, 2007 | 02:53 PM
Midwest Vette's Avatar
Midwest Vette
Originally Posted by ch3no2
Red!!!!!
To Caliper bracket bolt question
