Changing The Turn Light
Old Jun 26, 2007 | 06:48 PM
Borracho's Avatar
Borracho
Default Changing The Turn Light
Any tips on changing the Turning light on a C-5?
It looks like a pain.
Old Jun 26, 2007 | 07:24 PM
corvettedoug's Avatar
corvettedoug
If it is the front turn signals there are a few ways to access the bulb. My preffered method is to turn your headlights on and back off one notch. This turns the light off but leaves the fixtures up. Remove the black plastic bezel and stick you arm through the hole.
You can also get to the bulb from the access panel under the car or brake duct.
For the back turnsignals just remove screws.
Old Jun 27, 2007 | 03:21 AM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
To Changing The Turn Light
