I'm a new 02 owner, My car is bone stock, power is good but doesen't really jump out of the hole like I think it should! I wiil not light up the tires at all with Trac. Control off. It's an automatic But with the torque and the HP it has I'm a little dissapointed in the bottom end performance Is this normal? Just curious Thanks.........Pat
That is why it feels like it bogs.Need bigger gears(3.15)'s or more and an aftermarket Tq converter 2800 stall or higher and it will feel like a completely different car.jerry
Look on your Glove Compartment door for the "Service Parts Identification" label.
G90 is a 3.15 axle ratio
GU2 is a 2.73 axle ratio
Both of these are listed as "automatic transmission only" I have trouble breaking much loose with the Traction Control on as well. However I have the 3.15 too, I hope you find the troubles and..Happy Trails!
You need gears !! I had the 2:73's and couldnt even squeal the tires. I now have 3:90's and roast them off with ease.
I have a 4:10 rear w/ hardened shaft for sale for $ 550.00 that whines a little when letting off the throttle.
I also have an auto with the stock rear end. I find it very hard to get the rear tires spinning on any surface. The local tuner (FLP) will be installing a new 3.42 rear end in a few weeks. This change along with a basic tune for shift points should really change the low end response and let me burn off a bit of tire tread whenever I want. I will post results after the upgrade.
