Carbon Buildup
Old Jun 27, 2007 | 03:40 AM
Camaroguy22's Avatar
Camaroguy22
Default Carbon Buildup
Today when me and my friend installed my LS6 intake and did the LS6 PCV conversion I noticed that there is alot of carbon and sludge buildup in the intake ports in my heads. My car currently has around 150K miles. Is it a good idea to clean it out with GM Top End Cleaner or Seafoam? Or should I just leave it alone. I have heard the opinion that the cleaner will free the buildup however it could become trapped in oil passages clogging them up causing more serious problems. I took some pictures however it will take awhile to post them up. (Need to find my camera cable )
Opinions are welcome and appreciated!
Old Jun 27, 2007 | 03:57 AM
skeet's Avatar
skeet
I would not clean but would buy a catch can from the vendor here, Elite Engineering. It will prevent oil vapor from condensing in the intake,valves,etc.
Old Jun 27, 2007 | 05:33 AM
vettenuts's Avatar
vettenuts
I use FP-60 and LC-20, both made by Lube Control. It is a two phased approach at controlling carbon. I recently had my intake off and the back of the valves that are hit with the incoming injection of fuel were spotless.
Old Jun 27, 2007 | 01:11 PM
Camaroguy22
Thanks for your response. My vette had a catch can installed by the previous owner. I never knew it had one until yesterday I found it tucked up and hidden. It had a 50 cent piece sized whole in it, that would probably explain the large amount of debris I found under the intake manifold...(grass etc)
After vacuming that all up the ports still look cruddy. I sure whish I could get some pics up of what exactly.
I might go back to another catch can.
Old Jun 27, 2007 | 01:12 PM
Camaroguy22
I will have to take a look at that.
Old Jun 27, 2007 | 01:30 PM
MUKAK's Avatar
MUKAK
me 2
Old Jul 8, 2007 | 06:17 AM
Camaroguy22
http://rides.webshots.com/photo/2517...85852410ZTulqS
http://rides.webshots.com/photo/2490...85852410fFPdyR
http://rides.webshots.com/photo/2219...85852410jLCicj
Finally I have pictures. Do you think there is too much buildup to safely clean it out?
Old Jul 8, 2007 | 08:17 AM
rws.1's Avatar
rws.1
IF you are concerned, I would switch to a top tier gasoline and add SeaFoam to the next few tanks of gasoline.
I supect you also have carbon bulk up on your valve stems and seats.
That is a milder ( ableit slower) was of decarbonizing the intake
Old Jul 8, 2007 | 09:29 AM
vettenuts's Avatar
vettenuts
Other option is the method I use (see post above) which will clean and keep it clean.
To Carbon Buildup
