heating problem
Old Jul 5, 2007 | 04:43 PM
myblackC5's Avatar
myblackC5
Default heating problem
my cars starting to run hot! i turn on the air and the temp goes down. does the BCM control the fans and the transmission? i had to change the PCM i wondered if there was a connection.....
Old Jul 5, 2007 | 05:58 PM
happa's Avatar
happa
not sure but try to replace your thermostat, it seems to be the first to go. Good Luck!
Old Jul 5, 2007 | 10:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The BCM does not control power train functions!! The PCM does. How hot is hot?? Do you have ant DTCs??
BC
Old Jul 5, 2007 | 11:12 PM
65GGvert's Avatar
65GGvert
If the thermostat was stuck, turning on the air wouldn't make it cool down. Turning on the air turns on your fans, so it's possible that the fans aren't being turned on at the proper temps. Do whatever Bill Curlee says.
Old Jul 5, 2007 | 11:19 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The AC turns on the fans therefore it will run cooler. But if its heating up fast when you come to a stop with the AC off, I will venture a guess that your AC condensor in front of the radiator is plugged up with road debris. Thats means you probably have a ton of small rocks in there. Use a long air line with a bend in it and reverse blow out the rocks. You can get one of these from Harbor Freight for like $5, then connect to a air compressor.
Old Jul 6, 2007 | 04:47 AM
golfman2008's Avatar
golfman2008
St. Jude Donor '05
Here is an option , redirect the air flow right on to the radiator face.
" Turn Your Bottom Breather Into a Ram Breather "
http://www.C4orceCorvette.com
To heating problem
