C5 427 Dyno Results
Old Jul 9, 2007 | 01:09 AM
atljar's Avatar
atljar
If you disable your PE delay you can get rid of that lean tip in that you see at the begining of your pull. Worth a couple more hp/ftlbs down low. looks good
Old Jul 9, 2007 | 08:00 PM
7LitreC5's Avatar
7LitreC5
Thanks, I'll check that out!
Old Jul 10, 2007 | 06:23 AM
David426's Avatar
David426
494.41 at 5800 rpm looks nice
Old Jul 10, 2007 | 09:45 AM
STLKillerC5's Avatar
STLKillerC5
Wow! Nice numbers! In a couple of years I might look at doing something like this. Total cost for this mod package?
Old Jul 10, 2007 | 09:53 AM
02gt350's Avatar
02gt350
500 rwtq
Old Jul 10, 2007 | 05:36 PM
dhirocz's Avatar
dhirocz
I got wood looking at this thread I'm putting together a 427 based on a sleeved LQ9, and this is just awesome. I run the same rear tires. I want to go a little bigger on my cam, but not too big...
I bet that thing has little to no lope at all! Got a sound byte? I dont want to select a cam based on sound, but it will give me a rough idea where the power is based on the lopiness. I wanted to go with something around a 240/250/114... I havent selected a cam yet and I'll be around 11.3:1... dont want to kill off more bottom end than necessary to meet my 550rwhp goal. Damn this is awesome!
I love big cube engines. What is your mileage like, city/hwy?
Old Jul 10, 2007 | 09:18 PM
7LitreC5's Avatar
7LitreC5
It has a little bit of lope but nothing radical. Do a search for posts by me. I did post a sound bite on another thread that I started.
I only have a little over 500 miles on the engine right now but so far the mileage is 16ish city and 23ish on the highway.
I wish that affordable big inch engines were available 5 years ago. I'd have never bought the Vortech supercharger that I had.
Old Jul 10, 2007 | 09:28 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^I am curious as to why you like the big cube motor over the SC motor since I have been thinking about going one way or the other.
Thanks.
Should say your motor looks great and that torque curve is something else!!!
Old Jul 10, 2007 | 09:31 PM
edcmat-l1's Avatar
edcmat-l1
Low end torque. Simple as that.
Old Jul 10, 2007 | 09:45 PM
7LitreC5's Avatar
7LitreC5
Just like edcmat-l1 said. There is a lot more power under the curve.
When I had the Vortech with headers at 8psi it made 501 rwhp and 463 rwtq (current kits will do better than that). I now have 7 less hp and 30 more torque plus way more low end torque. I also don't have that extra 70-80 lbs on the front end and I don't have all the extra stuff on the engine that the blower has.
Thanks.
Old Jul 11, 2007 | 08:23 AM
Independent1
St. Jude Donor '08
^^Thanks for the reply.
That is really some motor, both in terms of power and looks. I saved this thread for future reference.
Old Jul 11, 2007 | 08:31 PM
Just Enough's Avatar
Just Enough
If you are still running a MAF you can gain quite a lot on top by going with a Lingenfelter or Halltech 100mm MAF. You have a similar cam as my 440 (232-240-117) and I was peaked at 6000 rpm like you with the 85mm MAF, when I installed the 100mm Lingenfelter it now pulls hard to the rev limiter at 6500.
Old Jul 11, 2007 | 08:44 PM
  #33
7LitreC5's Avatar
7LitreC5
That is great info! I am still running the stock MAF.
RMCR, the shop that did my installation, suggested the LPE MAF as well.
Do you or anyone else think that an air bridge would make any difference? I am still running the stock air bridge too.
Old Jul 12, 2007 | 12:27 AM
  #34
dhirocz's Avatar
dhirocz
Good info. I should plan on doing that. Hell I bet if you fully optimized that setup you could get 550 with a cam that is a touch bigger... I might need to reconsider my cam selection to something more tame, like a 230/236/114.
I just want 550. After looking at how tame your cam is and the similarities in the setup, I would think it is completely doable with a near stock idle
Was your car dyno tuned or mail order?
Old Jul 12, 2007 | 06:25 PM
  #35
7LitreC5's Avatar
7LitreC5
I am certain that there is more in it. I did the tune myself using EFILive. I am still learning...
Old Jul 14, 2007 | 08:45 AM
  #36
Pipedream's Avatar
Pipedream
Thanks for the info...
What length pushrods did you use???
Congrats on the numbers...
Old Jul 14, 2007 | 09:27 AM
  #37
dhirocz's Avatar
dhirocz
Cool... I think I'm going to go with a TSP 233/239/114 on mine. Only cam I can find close to the 234/242 I wanted...
Thanks for this info!!! Helps out alot in the cam decision
To C5 427 Dyno Results
Old Jul 14, 2007 | 09:36 AM
  #38
Gonzo's Avatar
Gonzo
WOW, those are awesome. That is one sweet Beast
Old Jul 14, 2007 | 03:28 PM
  #39
7LitreC5's Avatar
7LitreC5
Mine wanted slightly shorter than stock pushrods to get the valvetrain dead on. We ended up using Comp 7.350".
Old Jul 14, 2007 | 03:29 PM
  #40
7LitreC5's Avatar
7LitreC5
If you want a 234/242 then that is what you should get. It costs about the same to buy an off the shelf cam as it does to have Comp grind you exactly what you want.
