HELP installing DRM brake ducts
Instructions say put ABS wires in center of hose.
WTH does that mean?
Where do you point the end of the hose?
Toward the center of the hub? That is solid (backside of knuckle/spindle)
Or aim down a little so air is aimed toward the bottom of the rotor?
What do you zip tie the end of the hose to?
The ABS connector bracket?
I'll eventually get spindle ducts but don't have them right now.
Appreciate the help.
I'm off to install the other duct and will check back before I put the hoses on.
WTH does that mean?
with Pheonix spindle ducts
"Instructions say put ABS wires in center of hose.":
cut a slit in the hose and insert the ABS module and wire though the slit
"Where do you point the end of the hose?
Or aim down a little so air is aimed toward the bottom of the rotor?"
YES center of the hub is best but rotor is fine too.
"What do you zip tie the end of the hose to?" That is what the spindle ducts are for. To use a hose clamp and hold on the end of the hose
HTH
Tom
HTH
Tom
It was a long afternoon. Besides the ducts, I changed the oil, installed stnls brake lines, Hawk pads all around, replaced brake fluid with Motul 600. Finally got it all back together and cleaned up about 1AM.
