car would not turn over
Old Jul 8, 2007 | 08:31 PM
c3&c5 vets's Avatar
c3&c5 vets
Default car would not turn over
went to start my 2003, made a sound like it was going to turn over, then died. nothing worked, no radio, nothing. hooked a charger to it, all it would do was click.
so i took the battery form my 78 and put it in, started right up.
now the check engine light is on and was wondering if anyone had any ideas why. it was never on today while i was driving it, before it failed to start.
battery was only 10 volts. going to replace the delco with an optima this time.
any comments welcome.
thanks
Old Jul 8, 2007 | 08:53 PM
Dave68's Avatar
Dave68
Find out what the code is and post it here. Low-voltage codes because of a weak battery are probably not anything to be concerned with, but a check engine light? Let us know what you find.
Regarding Optimas - lots of premature failures reported here in this forum, so I am a bit concerned. Sears does have a new Platinum, but initial reports are that they are very heavy compared to the AC Delco batteries.
Old Jul 9, 2007 | 12:08 AM
c3&c5 vets's Avatar
c3&c5 vets
thanks dave:
here are the codes:
PCM P1518
BCM B0432
B0502
B0507
B2482
B2587
B2592
B2809
LDCM B2282
B2284
U1064
RDCM A2283
B2285
U1064
SCM B0851
B2860
U1160
U1064
Old Jul 9, 2007 | 09:01 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
1518 is whats causing the light, which is the serial bus connecting the PCM and TAC modules.
Since your battery was dead and you tried to start the car I'd be willing to bet thats why you have the fault, erase all of them and see if anything comes back.
If you don't know how to erase codes then follow the instructions in this link:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Jul 9, 2007 | 09:26 AM
c3&c5 vets's Avatar
c3&c5 vets
ok, will do. i got the correct battery and i'll put it in today. only used the one from my other corvette so i could get it home.
once i do that, i'll clear the codes.
thanks again.
Old Jul 10, 2007 | 01:18 AM
c3&c5 vets's Avatar
c3&c5 vets
cleared the codes, no check engine light. hopefully it will be ok. don't think the battery's fully charged yet. shows 13.5-13.8 and drops a little when i brake and signal. have my battery tender on for the night. hopefully be fully charged in the morning.
Old Jul 10, 2007 | 05:25 PM
Ron222's Avatar
Ron222
thanks
Don't know if this would cause the check engine light to go on but then again it might....I can only speak for my '04 but the minimum CCA for the battery has to be 590 if its less you can run into problems, don't know what kind of cca's the battery from your '78 had. When my orig delco took a dump I put the Red top in without a hitch.
Old Jul 11, 2007 | 06:37 PM
c3&c5 vets's Avatar
c3&c5 vets
thanks, i put the recommend ac battery in again because i couldn't find an optima locally. i'll keep an eye on it.
To car would not turn over
