guys with T1 sway bars....
For general street use I would say they are a bit overkill, but then again if you want less roll they are the way to go.
what tires are you using because that will come into play too. I think the t1s are too much for stock tires and you will not benefit from the t1s with stock tires.
BTW - I use adjustable endlinks which are much stronger than the oem metal endlinks
(disregard the scorpian remark at the top.... i screwed up)
I also checked them on the forums and their reputation was extremely high. After a long talk with Aaron the owner, I knew these were folks i wanted to do business with.
I ordered a set, popped them on, and WOW....they are true artwork for your undercarriage-simply beautiful design. they have a spline mechanism that is fully adjustable for street or track use-with absolutely no slippage that I could detect. On the street, at the easiest setting, they are slightly stiffer than the stock Z06 bars, but not bone jarring-and quiet as a church mouse.
I set them on the next to highest stiff setting for a recent track event at Mid-Ohio, and oh man, my Z06 is just dead neutral through turns. I picked up 3 seconds in time consistently from my last trip to Mid-Ohio 3 weeks ago. the only change was the anti-sway bars. air temperature was very similar during both sessions. same tires...
I notice the difference particularly in off camber turns as well as S type curves where the chassis has to turn hard left then right. with the new bars, I don't have to pause to settle the chassis before turning the opposite direction. Now I can just flick the car through the twisties and it stays planted with just the slightest hint of understeer-perfect....
If you don't track use OEM links and eliminate the noise.
