throttle stick
Old Jul 10, 2007 | 06:44 PM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default throttle stick
anyone have a throttle stick, my throttle stuck at 300 0t0 3200 rpm for about 3 to 5 seconds. i push it hard thru 3rd gear and when decelarating with clutch in see was sticking. also throwing codes tcs c1282, 1287, 1288 and one more bo rfa u1064, will any of these effect the throttle. also just had avic d3 install in car.
Old Jul 10, 2007 | 07:41 PM
BlackZ06's Avatar
BlackZ06
None of those codes will affect the throttle ....
C1282 - yaw rate sensor error
C1287 - steering wheel angle sensor fault
C1288 - steering wheel angle sensor fault
The U1064 can be deleted and ignored (communication failure - these happen frequently between the car's computers).
The throttle is controlled by computer. When you step on the "gas pedal" there are sensors that determine how far down you are pushing the pedal. That data is transmitted to the PCM and it decides how much actual throttle to deliver (it may deliver less throttle if Traction Control says the rear wheels are spinning). The throttle position is then controlled by the TAC (Throttle Actuator Control) which directly controls the setting (opening) of the throttle plate.
If you have a "sticking" throttle it is most likely an issue with either the Throttle position sensor, or the TAC. Clear all codes and see if a new one comes up the next time the throttle "sticks" ... if no codes, the throttle position sensor is probably going bad.
HTH
Old Jul 10, 2007 | 07:55 PM
vettenuts's Avatar
vettenuts
Not sure what this is?
Old Jul 10, 2007 | 08:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There have been instances where the throttle blade gets very dirty or the gears inside the Throttle Body bind. The throttle position sensor circuit is pretty bullet proof and it has fail safes built into it so there are not any problems like this. There are two circuits in the TPS. One that is high when the throttle is shut and the other is low when shut. The same for the accelerator peddle. If the TAC module see's conditions that don't all add up, the system goes into reduced power mode and buddy,,,,you going NO WHERE in a hurry. You will be lucky to be able to do 5 mph! Been there, done that.
I would make sure that your accelerator pedal is free to move and the Throttle blade is clean and free to move. It's on a spring so it has resistance to open. When it shuts, it will NOT shut fully. If you push it open it will spring back nice and smooth. I clean my Throttle Blade with Carb Cleaner.
BC
To throttle stick
