car overheating need help, please
Mark
Bill
Mark
Mark
Mark
The stock thermostat is nominally a 190 F unit. Once the system heats up, the lowest temperature it will run is 185-195 F, depending on the individual thermostat. Below that temp, the thermostat begins closing to maintain that temp. My 02 runs at 194 when the thermostat is closed, and there is airflow through the radiator.
During stop and go traffic, or any other situation where there is low airflow through the radiator, the coolant temp rises if the AC is off (ie the fans are off.) At about 228 F (approximately, the temp varies slightly with model year), the fans (both of them) will come on at low speed. If outside temps are cool, this may be enough to lower the temps. If the temps do keep rising, at about 235 F, the fans will go to high speed. The temps you mentioned are ops normal for an unmodified C5 cooling system.
If you have your AC on, the fans will run any time you are under 30 MPH and the coolant temp is over 165. If you turn off your AC, the fans will go off and your temps will rise.
Its at the dealer today, pray for me! I hate having to take it to the dealer but it is still under extended warranty and I had to get the horn membrane replaced anyway (not a job I wanted to do).
