C5 Fan Trick
Old Jul 18, 2007 | 01:53 PM
Ranger's Avatar
Ranger
Default C5 Fan Trick
Get a chance to hot-lap at the drag strip? Hate paying that horsepower penalty when the coolant temp soars? There is a work-around short of a fan switch or tuning the PCM.
All it take is a 6 inch piece of wire and a couple minutes to do the set up the first time. After that about two minutes each time you go to the track. Helpful in the summertime too; keeps the engine temps in the range for good power.
I put up a page at my site with a how-to for turning on the fans without tuning or a switch.
Here is a link: C5 Fan Trick.
Ranger
Old Jul 18, 2007 | 02:25 PM
Tomulrich's Avatar
Tomulrich
is there a way to get them to run on high?
Tom
Old Jul 18, 2007 | 02:32 PM
Ranger's Avatar
Ranger
Tom
Not without more extensive wiring that I wanted to do.
With the low-speed fans on, I never saw a coolant temp above 195 even on four passes four minutes apart. Most I ever did literally back-to-back at a rental.
Ranger
Old Jul 18, 2007 | 02:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW,,,you could even solder a small switch in the jumper, velcro it to the relay and just leave the wire in place and flick the switch when you want the fan to come on!
Old Jul 18, 2007 | 02:49 PM
rws.1's Avatar
rws.1
thanks for sharing....
Old Jul 18, 2007 | 02:53 PM
dogboy's Avatar
dogboy
Thats what I was thinkinking also. Great tip for the fans btw
Old Jul 18, 2007 | 03:04 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
great information on clutch fluid, nice site
Old Jul 18, 2007 | 10:03 PM
prochargedz's Avatar
prochargedz
thanks ranger, i did this mod tonight. My car was running hot with the d1sc. i was seeing 230 all the time almost in this 90deg heat in md. i wired an interupter switch, so i can just flip a swith and the fans stays on till i turn it off. kevin
To C5 Fan Trick
