Where is the memory module?
Old Jul 19, 2007 | 03:06 PM
ragtopws6's Avatar
ragtopws6
Default Where is the memory module?
Is it on the driver's side door? Does it control the power driver's seat and mirror?
Old Jul 19, 2007 | 09:41 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You need to be more specific on which one. There are several located throughout the car. There is a Left Door Control Module (LDCM) which runs the locks, window and mirror. The Seat Control Module (SCM) which runs the seats and telescoping steering wheel. Just a few others, like the PCM, BCM SDM, RDCM, EBCM and so on...
Old Jul 19, 2007 | 10:36 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
If you are looking for the Memory module/receiver. It's in the left rear quarter area, behind the driver's seat.
Old Jul 19, 2007 | 11:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MEMORY MODULE RECEIVER? Your referring to the Remote Function Actuator (RFA) Module which receives the radio frequencies form the FOBS and the Tire Pressures Modules and transmits the decoded signals to the BCM which in turn signals the function to happen or tells another module to preform a certain function.
I agree with dgrant3830 There are a few memory function modules. What is your exact issue and have you read the DTC's to see if there are any codes set?
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too! 
BC
Old Jul 20, 2007 | 10:44 AM
ragtopws6's Avatar
ragtopws6
I have replaced the drivers door from a 02 Vert. When I installed the new power seat, the seat and the drivers mirror has a preset position. Every time I unlock the doors with the remote, the seat and the mirror moved to pre set position. I have replaced the seat track with a manual one but the mirror still moves every time I use the remote to unlock. Do I just replace the drivers door module from my 99?
Old Jul 20, 2007 | 12:32 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
You can turn the memory function off using your DIC. Its about a 30 second job.
Old Jul 20, 2007 | 12:36 PM
ragtopws6's Avatar
ragtopws6
Even if my car didn't come with memory option?
To Where is the memory module?
