Installing CAGS this weekend, quick question.........
Old Nov 1, 2001 | 11:46 AM
New-B's Avatar
New-B
Default Installing CAGS this weekend, quick question.........
Do I "HAVE" to take the wire off the neg battery terminal? I don't want to have to reprogram things like FOB synch, stereo security thing, etc. What else would I have to reset or reprogram? In the instructions that came with the CAGS unit it says to do this, but if it will work w/o it then I don't want to do it. Thanks in advance.....
Chris
Old Nov 1, 2001 | 11:54 AM
jbalch's Avatar
jbalch
Default Re: Installing CAGS this weekend, quick question......... (New-B)
New-B,
I installed mine and did not disconnect the battery and everything works fine. It appears that it would be difficult to "short" anything out because both plug-ins are heavily insulated with plastic.
Old Nov 1, 2001 | 11:59 AM
New-B's Avatar
New-B
Default Re: Installing CAGS this weekend, quick question......... (jbalch)
Thanks for the tip jbalch, I'll give it a try :cheers:
Old Nov 1, 2001 | 12:00 PM
Yellow 01 Coupe's Avatar
Yellow 01 Coupe
I have installed 2 CAGS bypasses and I did disconnect the battery each time. The only thing I had to reset was the time on the clock. I did not have to do anything with the key fobs or the radio security (although I don't think the radio security feature was turned on to begin with)
Old Nov 1, 2001 | 12:44 PM
mprp's Avatar
mprp
Cruise-In II Veteran
Default Re: Installing CAGS this weekend, quick question......... (Yellow 01 Coupe)
I installed mine w/o disconnecting the battery, and no problems. :D
Old Nov 1, 2001 | 12:58 PM
jschindler's Avatar
jschindler
Default Re: Installing CAGS this weekend, quick question......... (mprp)
I've done them with and without disconnecting battery. No side effects either way.
Old Nov 1, 2001 | 01:55 PM
hmert's Avatar
hmert
I did not disconnect the battery either. No problems.
Good Luck, you'll love it
Old Nov 1, 2001 | 02:09 PM
dba4life's Avatar
dba4life
Default Re: Installing CAGS this weekend, quick question......... (hmert)
Same here. Didn't disconnect the battery. No problems.
To Installing CAGS this weekend, quick question.........
