Transmission Jack questions
I can get:
Transmission jack for about $100 (rated to 450 lbs)
Transmission jack for about $180 (rated to 800 lbs)
ATV/motorcycle lift for about $80 (rated to 1500 lbs)
I'm not sure that they 450 lbs jack will be good enough to support everything, and I dont really want to spend almost $200 on a jack that I will rarely use. I would be able to get more use out of an ATV jack, so I'm kinda leaning that way.
Has anyone own an ATV/motorcycle jack, and have you used it for a clutch swap? Does it go low enough to get the rear-end out from underneath the car? Does it roll ok with a load on it?
Any help is appreciated
Thanks!
EDIT ------------- Here is a picture of the jack that I'm thinking of using. I found a used one locally, and may be able to get it for around $50.
Here's the tranny jack we used to pull a buddy's drivetrain a while back and a series of pages showing how we did it.
http://redshift.homestead.com/Drivetrain1.html
Here's the one I bought recently to pull the drive train on my wife's C5 and the thread for that project.
I know there is a transmission jack/axle jack adapter that mounts to the top of a regular floor jack available through several sources. That might provide more lift. This one is only $50...
I have an inexpensive version (HARBOR FREIGHT) of the second image that Patches posted. I've removed transmissions and rear axles my myself with it (not C5/Z06 though). Those ears and chain really stabilize the load, plus there are adjusting tilt *****. It's paid for itself.
Have you checked with rental stores?
Thanks for the heads-up on that. I'm actually planning on using the tool that Dope used for his install (I'm using his directions as a guide).
As for the jack, I've decided to go with the Sears ATV jack (picture below). On sale for $149, rated to 1500 lbs, and with the wide base, it shoudl be pretty stable. I'll also be able to use it for other stuff too - not just for a transmission swap (I dont do too many of those
). I will make sure that I tie it down with some straps to make sure it doesnt shift.Thanks for all the input everyone!!!
Plus it was like $100 for both (find a friend w a coupon)
I just got done doing this with my automatic tranny when I was converting to a stick shift.
