Overheating issue - 02 Z06
I had this happen once before about 8 months ago after a day of drag racing, but I was able to tow the car home and I flushed and filled the colling system and replaced the factory thermostat with a Hypertech 160 stat. The problem didn't come back through any subsequent days of racing or driving until this weekend. The only constant things both days were the fact that I was racing and the car was left outside the night before and had condensation all over it during a 50 degree morning. Mods, tune, and type of racing were totally different.
Anyone have any idea what may have happened or had this happen to them before? I'd like to get this fixed before an October track day at Road America
. Thanks!
2nd get two bottles of water wetter. That will drop temps too.
Check your sensors, and your water pump.
Rember as your skill level goes up so does your driving and cars temps
My car started overheating sitting in traffic one day. Once I got it back up to speed everything was OK. Got it home and popped the hood, noticed that while idling the coolant level was low and air bubbles were being sucked down into the coolant lines from the tank.
Replaced the rad cap, topped up the tank with water, drove for a bit, topped off tank again. I drove the car for about three weeks before the coolant level finally stabilized. I thought at the time there was a leak somewhere, but I think it just took that long to finally work all of the air out of the motor.
My THEORY on what happened was that the rad cap was bad and was allowing steam to exit whenever the engine warmed up and pressure built in the cooling system. Over time that steam was enough to get the coolant low enough to allow air into the system. Once enough air got in, the water pump started to cavitate or run dry, coolant flow stopped, and my motor overheated. Once the revs came back up the pump got the coolant flowing again and all was well.
Check your rad cap; remove it and wipe off the bottom well. Put your mouth around the base (the part that sticks into the tank, not the outer threaded body unless your mouth is HUGE) and try sucking and blowing through the cap. You should be able to suck air in through the cap but not blow air back out through the cap.
I tried this on mine and it failed the test, '02Z with ~73k miles at the time of failure. Replacing the cap has been the fix so far, coolant level has been steady for about a month now.
Thanks!
Once I replaced the low speed fan motor, everything was cool.
QUOTE]
Had same problem when first got my vette. Got a new GM cap and solved the problem.
