Reason Found 4 Battery problems !!!
Old Jul 25, 2007 | 08:37 AM
stonecoldsaysto's Avatar
stonecoldsaysto
Default Reason Found 4 Battery problems !!!
This May help a lot of people with Battery broblems !?!?!
i just installed a new excide battery & all was ok til 1 morning it wouldnt start. cables were tight !??????? AT Least the screw was tight- BUT IT wasnt making contact real good w/ the battery, especially the positive terminal....... REASON is i used the battery terminal screws that were on the cables & they DID-NOT HAVE THREADS ALL THE WAY to the END, as a EASY FIX i bought 2 new screws for the terminals that were shorter & threads ALL the way on the shaft ---so when You tighten the cables -- not only are the screws tight BUT it pulls the terminal Next to the Battery for Positive contact ALL the time -- (cost less than $2.) Hope this helps a lot of You with battery problems, which is possibly why the battery sometimes doesnt charge !!!!!!!!!!!!!!!
Old Jul 25, 2007 | 09:03 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Good tip, many times it's the simple things
Old Jul 25, 2007 | 11:17 AM
Mike Mercury's Avatar
Mike Mercury
Old Jul 25, 2007 | 11:19 AM
RedY2K's Avatar
RedY2K
Thanks for sharing.
Old Jul 25, 2007 | 11:54 AM
csexton's Avatar
csexton
Good info.
Chuck
Old Jul 25, 2007 | 02:48 PM
rws.1's Avatar
rws.1
I'll have to look at mine...
thanks for sharing.
Old Jul 25, 2007 | 03:52 PM
Dave68's Avatar
Dave68
A good way to check is to try to rotate the clamp. If you can rotate it, it isn't tight enough. The same holds true for hose clamps.
Old Jul 25, 2007 | 04:13 PM
jrose7004's Avatar
jrose7004
It pays to check the basic items.
To Reason Found 4 Battery problems !!!
