A/C Quit
Old Jul 31, 2007 | 09:21 AM
projectjim's Avatar
projectjim
Navigator
Default A/C Quit
My air cond. quit working this morning.The light on the A/C switch just flashes in goes right back off.I've been noticing my external temp has been showing wrong for about a month now.This morning is was about 78* outside and it was showing 32*.Would this cause the A/C not to work?Are they tied together?I haven't put any gauges on the system at all yet.Just was thinking that the ext. temp sensor might have something to do with it.Where is the sensor located?Thanks in advance.
Old Jul 31, 2007 | 09:25 AM
projectjim's Avatar
projectjim
Navigator
I forgot to add that it's a 2000 with dual climate control.
Old Jul 31, 2007 | 09:39 AM
Midwest Vette's Avatar
Midwest Vette
When the hvac light flashes it should be sending a code to the DIC. Did you check for codes?
Old Jul 31, 2007 | 10:15 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The system thinks it TOOOOO COLD outside to function. Clean the connector and electrical contacts in the external temp probe or replace it with a new one. Thats a first thing that you need to do. If the system thinks its too cold out, it will not set a code but the compressor will not function until it senses or gets the signal thats it warm out.
Old Jul 31, 2007 | 10:36 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default outdoor temperature sensor?
Didn't I see a post regarding an outside temperature sensor near the radiator intake? If it goes bad then you get the problems described? I saw some pictures in the post showing the sensor in the post? Good Luck and I hope you get her fixed.
Old Jul 31, 2007 | 11:19 AM
TLewis4095's Avatar
TLewis4095
Where are you located? We do A/C checks & diagnostics for free...
Old Jul 31, 2007 | 01:34 PM
projectjim's Avatar
projectjim
Navigator
Dalton,Ga.
Old Jul 31, 2007 | 01:38 PM
projectjim's Avatar
projectjim
Navigator
I tried cleaning it and it didn't change.I went and bought a new one for $10.07 from the dealer.I couldn't believe it was that cheap.It still shows ext 32*.
Old Jul 31, 2007 | 01:41 PM
projectjim's Avatar
projectjim
Navigator
You probably did.I had to do a search to find it.It's right below the frame rail on the passenger side,infront of the radiator.Sounds kinda complicated,but it's actually easy to get to it.
Old Jul 31, 2007 | 02:29 PM
projectjim's Avatar
projectjim
Navigator
I disconected the battery and left it unhooked for 15 minutes.Reconected it and it now shows 92*(it's hot here today).The A/C now works. I guess I should have done that when I first put the sensor on,as I have no way to clear any codes.Either way thanks for the help!!
Old Jul 31, 2007 | 05:53 PM
TLewis4095's Avatar
TLewis4095
Glad it worked out, and at a very reasonable price!
Old Jul 31, 2007 | 11:13 PM
projectjim's Avatar
projectjim
Navigator
Thanks.I'm tickled over it.
Old Aug 1, 2007 | 12:46 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Damn,,,,,,,,There must be 100,129 post on reading and clearing DTC on this site.
So, heres the 100,130 post:
Check this website out:
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too! 
It will allow you to read and clear ALL your DTC "without having to buy or use an expensive aftermarket scanner!!!
BC
Old Aug 1, 2007 | 12:00 PM
projectjim's Avatar
projectjim
Navigator
BC
Guess you can tell I'm a newbie.Thanks for the info!!
To A/C Quit
