Which spark plug wires?
Old Aug 6, 2007 | 11:32 AM
Kal-El's Avatar
Kal-El
I appreciate all of the advice; however, the last plugs on my car lasted for over 60k miles which included cross country trips, easily over 100 runs down a drag strip and over a dozen weekend racing events and never needed sleeves even with the headers. They were changed because I felt like it was time not because anything was wrong, and my Vette has not run as well since. Plus I could have the Taylors by Monday and the best I could find for the Z06 wires was 5 - 7 business days.
Old Aug 6, 2007 | 10:08 PM
ROJ#79's Avatar
ROJ#79
Originally Posted by BlackZ06
Take a look at the GM Performance wire set - Part number 12495519 - I have them on my Z06 and they work great.
Old Aug 7, 2007 | 08:01 AM
rws.1's Avatar
rws.1
Autolite from Autozone
Old Aug 7, 2007 | 10:18 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Anything other than stock wires (or autolites) and you're wasing money.
The stock iginition on these cars is good to over 1000 horses... ask any big tuner. There is no need for the fancy MSD coils or expensive wires, they do nothing.
We have individual coil on plug w/ 6" wires... it's hard to improve upon. The only time you'll notice a performance gain are if your mind is playing tricks on you or you had something wrong before the swap.
Plus, the oem wires have oem heat shields and the wires click into place w/ a very positive connection which most aftermarket wires don't do.
If your headers are very close get kool-sox or fire sleeves. I have Kooks and they don't come close at all... I've been running HPDEs for 4 years w/o any extra wire protection other than the oem shields w/o issue.
Old Aug 7, 2007 | 01:07 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Brian is correct, we have a few 600plus hp cars running stock wires, nothing to be gained here
the red GMPP wires a good replacement at around $65
Old Aug 7, 2007 | 03:44 PM
98Z51's Avatar
98Z51
I'm using Magnecore's, they are red and the stock heat shields fit. They seem to be working fine after 40,000 miles. I think I paid around $75 for the set.
Old Aug 11, 2007 | 05:55 AM
AMGPilot's Avatar
AMGPilot
Do you happen to remember the part number for them?
Old Aug 11, 2007 | 08:16 AM
DVS 99's Avatar
DVS 99
MTI RACING are the wires to use. Fitment is great. But they are 100$
Old Aug 11, 2007 | 08:41 AM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
Originally Posted by Kal-El
I spoke to a mechanic who worked for the shop who originally put on my headers. He said that the shop uses Taylors. I have ordered a set and should have them by Monday. Thanks for all the help.
I like Taylor wires and have used them on many of my cars, but Taylor "spiral core" wires caused noise on the radio of my '02 Z06. When you change wires again go with the red GM performance wires, they worked the best of the six different brands I tried on my car.
Old Aug 12, 2007 | 02:14 AM
dmoore's Avatar
dmoore
The Red GMPP wires are a good replacement I just put those in with the headshields and have had no problems.
Old Aug 12, 2007 | 12:52 PM
rikhek's Avatar
rikhek
ttt
