which direction? shifter installation
I hope you didn't force it into reverse and do any damage. It's been awhile since I had mine opened up, but I believe that slot should be facing towards the rear. Someone will correct me if I'm mistaken...
The B&M shifter in that article also appears to be symmetrical for installation purposes. This article suggested installation with the slot facing rearward. In re-reading it, that suggestion has more to do with the installation of the oem **** and "demon key" orientation. The KIRBAN removable lever would make this unnecessary.
You might simply need to loosen the four mounting bolts and make sure the shifter sits perfectly square to the box beneath to eliminate the hard to achieve reverse gear.
Post follow up to your impressions of the KIRBAN shifter. It is probably the only shifter I would consider installing in my car in the future. I like the idea of the removable lever.
As far as the 1-6th gear experience... I'm very happy with it. The throw isn't quite as short as the B&M, but still a vast improvment from stock. No more mushy shifting.
The B&M shifter in that article also appears to be symmetrical for installation purposes. This article suggested installation with the slot facing rearward. In re-reading it, that suggestion has more to do with the installation of the OEM **** and "demon key" orientation. The KIRBAN removable lever would make this unnecessary.
I really like my KIRBAN. It has an added centering force that helps prevent missed shifts. It also practically eliminates the 3rd to 2nd shift problem!
Granted, a lot of that problem has to do with shift technique but, the precision of the shifter makes accurate lighting fast shifts simple!
I have had owners of other C5's with aftermarket shifters drive mine and make the statement " man, I really like your shifter, what kind is it???"
BC
I've tried to find out who manufactures them for KIRBAN. KIRBAN doesn't manufacture them per websites of vendors who sell them. I didn't even find them listed on the KIRBAN website. It seems they're more geared towards the Buick GNX and late model Mustang. KIRBAN didn't return messages.
They look like the CALLAWAY shifter, but CALLAWAY says they are not a KIRBAN. I just missed one on EBAY because someone else wanted it more than I did.
