My turn signal works some of the time. It will not turn on sometimes then will turn on within several turns later. It did this for a wile then stoped for 3 months. It has started again and quit on the same short trip. I need your help in what to look for,Thanks,
try the "hazard switch" quick fix. The turn signal relay runs through the hazard button in the center of the dash. When my turn signals stop blinking, I jab the hazard switch hard a few times, loosen up the contacts, and the turn signals will work for a few weeks. I've been busy with other projects, but will need to change out the switch at some point. This has been a fairly frequently reported issue.
Having the same problem with my 2000. THanks for the post.
