Installing roller rockers, need help with zero lash.
Old Aug 8, 2007 | 01:17 AM
99Lingenfelter's Avatar
99Lingenfelter
St. Jude Donor '07
Everything is put back together and the car is running great. The install was definatelly a PITA, but it was well worth the effort. I can't wait to hit the track. There's also an autocross event coming up this weekend and I can't wait to put the sticky tires on and make some runs.
I noticed a lot more low end torque with the crane quick lifts and would recommend them to anyone. If your looking for a quicker easier install, I would recommend the yella terras.
Thanks for all the help!
Old Aug 8, 2007 | 05:35 AM
vettenuts's Avatar
vettenuts
Was on a business trip yesterday so I didn't see you were having a problem until this morning. Glad you got it straightened out. As I mentioned above, finding zero lash is where everyone initially struggles. When I installed my new Morel lifters, I found the lifter plungers were so soft that I couldn't use the Vinci method of setting up the rockers and reverted back to the old small block method of doing them one at a time depending on the position of the other valve. It took hours.
