Storage: Jackstands vs. ground...
Old Nov 4, 2001 | 08:52 AM
mrspice's Avatar
mrspice
Default Storage: Jackstands vs. ground...
Ok, I got some good responses from my battery tender question....now, do I want to let this sit on the tires for 4 months in one place or jack it up and leave it on jack stands. I would rather leave it on stands as this would make it convienent to work on. Is there any problem with this? :confused:
Old Nov 4, 2001 | 10:06 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Storage: Jackstands vs. ground... (mrspice)
do a search for JOHN Z as he has posted why not to leave the car on jack stands. i may be wrong on this it could have been DUKE that posted. i follow too many boards.
[Modified by clem zahrobsky, 9:20 AM 11/4/2001]
Old Nov 4, 2001 | 10:32 AM
vettenuts's Avatar
vettenuts
I am looking at the same thing right now. I would be interested in any threads or other information you find. Also, I use heavy wood blocks rather then jack stands. I don't trust jack stands as they can rock if you are doing heavy work that requires a bit of torque.
Old Nov 4, 2001 | 12:54 PM
Z06inator's Avatar
Z06inator
Default Re: Storage: Jackstands vs. ground... (vettenuts)
I assume you are using heavy duty stands..
Balancing the car on pucks on stands can definitely be tricky. A decent quake in seattle would *really* ruin your day.
I'm working on a little adapter to the puck which locks it to the stand..
I think one of the bigger worries I have about stands is whether the surface is level. When you park the car on an uneven surface, the suspension compensates. But when it rests on stands, the frame will be stressed. The C5 is very stiff, but a few months of loading will take a toll. Especially if you park it in that same uneven spot, season after season.
On a regular car, the frame will twist and full contact non-level jackstands. A stiff car won't (at least not at first). I don't have my Z06 yet, so I'm not sure what it will do. My very stiff race car pivots. If one stand is 1/8" lower, you can pivot it.
I believe this is another reason why you want rubber pucks that have some give instead of solid wood pucks.
Supporting the car by 3 points solves the level issue.
I'm working on an elegant solution to this problem that will *really* solve it. But I need to develop and test it on my own car first.
Old Nov 4, 2001 | 12:59 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: Storage: Jackstands vs. ground... (BrianK)
if you are worried that the tires will flat spot,that is not a problem with radial tires. my C-5 sets from dec to april with no problems.
To Storage: Jackstands vs. ground...
