How hot does your oil run?
Old Aug 8, 2007 | 10:34 PM
ShadowLight's Avatar
ShadowLight
Default How hot does your oil run?
I'm just curious what kind of temp range is normal for our car's oil?
Old Aug 8, 2007 | 10:42 PM
briann510's Avatar
briann510
Today was 80 degrees out and on the freeway doing 75 mph for 20 miles oil temp was 217, water temp was 187.
Old Aug 9, 2007 | 12:04 AM
Z06ster's Avatar
Z06ster
I live in Southern California also, and these numbers are also what I have typically seen.
Another data point I can add is that I drove out to the desert (Palm Springs) a few weeks ago where it was over 100 outside and while on the freeway, the oil temp got up to a hot 248! After that, I had a 180 thermostat installed and also upgraded my radiator to a larger one (A&A Custom). The stock radiator is a mere 1 inch thick.
Old Aug 9, 2007 | 12:13 AM
Bill Dearborn's Avatar
Bill Dearborn
Before I went to a Ron Davis Racing radiator with built in oil cooler I saw 319 while lapping at Watkins Glen. Now it runs in the 250s to 260s.
Bill
Old Aug 9, 2007 | 04:25 AM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Hottest i have seen my oil gauge is in the 220's here in Las Vegas. But in this heat i don't push it.
Old Aug 9, 2007 | 09:24 AM
ShadowLight
Okay so it's common for it to be around 220* just cruising. What about road course temps?
Old Aug 9, 2007 | 09:53 AM
VetteDrmr's Avatar
VetteDrmr
It depends on how hard you drive. As Bill mentions, you can easily push 300+ without a cooler and driving aggressively on good tires. Before I installed my external oil cooler I would monitor my oil temps and back off when the oil temps exceeded 280. Once the oil temps dropped back down into the 260s I'd go again.
After my EOC, I can run a full session now without the temps getting much above 270, even here in TX.
HTH, and have a good one,
Mike
Old Aug 9, 2007 | 11:09 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default 220-230 at Highway speeds
Mine runs between 220-230 at highway speeds. If I push it it can get to 240.
I seems to run a little hotter after I installed my 402/L76 combo.
Bob K.
Old Aug 9, 2007 | 11:26 AM
Last C5's Avatar
Last C5
80 degree day mine runs about 265 + -.
Old Aug 9, 2007 | 04:11 PM
eric04's Avatar
eric04
mine runs between 225 and 240 i am in fla its been very hot here lately
Old Aug 9, 2007 | 08:13 PM
Dave68's Avatar
Dave68
Summer: 210-220F after 20+ minutes.
Winter: 195F after 20 minutes.
I've seen 260F while climbing a mountain full of sharp curves. This is why I am glad synthetic oil is lubricating the engine.
Old Aug 9, 2007 | 09:10 PM
Joy of 6's Avatar
Joy of 6
I was at 280 for a track day last sunday at Portland. Air Temp was mid 70
Old Aug 9, 2007 | 09:45 PM
waterzap's Avatar
waterzap
On highway at about 75......203 oil and 194 water
Old Aug 9, 2007 | 10:16 PM
speedsk899's Avatar
speedsk899
Mine runs right at 216. I put in a 160 degree thermostat and had the fans turned down to come on at 180. The collant runs right at 174 on the highway, never over 190 in stop and go. but the oil stays at 216. I am looking into putting an external oil coller on mine
Old Aug 10, 2007 | 12:45 AM
DJMRTS's Avatar
DJMRTS
On a typical 82* summer day, my coolant temps stay between 194* and 198* no matter what. My oil temps average at 222* cruising at 70 mph on the freeway. On my last hard run through the mountains my oil went to 236* From what I understand this is normal. Funny thing is that my A4 tranny oil doesn't ever exceed 165*!
Old Aug 10, 2007 | 10:09 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
23X running on the street in the 97' at any outside temp....
32X at the end of a 25 minute session of 3.27 mile road race.......(heavy foot and far from stock with an iron 6.0L block)
Change the oil after a 2 day event..........have a nice day
The 00 coupe/vert is 215 crusing & 250 max pushing them on a road course in 80 deg weather
Old Aug 10, 2007 | 01:09 PM
waddisme's Avatar
waddisme
105 deg at VIR yesterday - mine got to 267 once after a 20 min on track. Most of time it stayed around 250. Coolant only got to 237, and all this is with a supercharger with heat index abouve 110. It was really hot. It is about the best I could ask for.
To How hot does your oil run?
Old Sep 5, 2007 | 10:27 PM
Mike94ZLT1's Avatar
Mike94ZLT1
My heads/cammed engine ran at 205 all the time with mobil 1 synthetic. I currently have Rotella 15W40 in my 383 LS6 for break in purposes and it likes to run in the 215-220 range, although on cooler evenings it seems to stay around 208.
Old Sep 5, 2007 | 10:48 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
was running at 230's stock 1999 FRC in not that hot, hiway drive. 240's when ******* it. Was driving me nuts. SO I did:
1.) Opened up the stupid fog light ducts, put in Z06 screen = more air
2.) callaway honker cold air intake
3.) changed the MAF housing to a no filter screem / honey comb polymer composit to cut down on heat sink
4.) 160 degree lingenfelter thermostat
5.) RP Oil 10w-30, will switch to 5w-30 only when it gets clsoe to freezing temps again in the late fall
6.) reprogram the fans to come on MUCH earlier
Now hiway driving I get a max of about 205 oil temp and about 180's for water temp, and thats when ******* it :-P Why do an oil cooler unless you are dragging...
Old Sep 5, 2007 | 10:52 PM
Z06 Bob's Avatar
Z06 Bob
Default OIL temps
Prior to install of DeWitts radiator with oil cooler 295+ running Pocono long course.
After DeWitts I run 228-30 consistently on Pocono and WGI.
