engine help
Old Jan 29, 2008 | 08:23 PM
CBR-runner's Avatar
CBR-runner
As i slowly move through this engine build little problems have popped up. some have been with the machine shop, others have sent me around town looking for the right tool, but the latest has sent me to the freezer. I was trying to install my ARP head studs and they would not thread into the block . I tried the stock bolts and they worked just fine . I wasn't not sure what to do.... my buddy said to freeze them . So i tried it and sure enough it worked like a dream . now all my head studs are in and the motor is ready for heads .
Old Jan 30, 2008 | 09:23 AM
Corvette_Brett's Avatar
Corvette_Brett
its amazing how freezing metal will get u that extra couple thousands u need. glad u got it figured out u know what they say. "if it goes together easy its because your doing it wrong, and if it fights u the whole way itll stay together forever.
Old Jan 30, 2008 | 03:21 PM
CBR-runner's Avatar
CBR-runner
Yeah i guess talking to some other people that the iron blocks don't have a problem with the ARP studs, just the aluminum blocks.
Old Jan 30, 2008 | 11:58 PM
jon c's Avatar
jon c
http://forums.corvetteforum.com/show....php?t=1924687
Old Jan 31, 2008 | 09:05 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Did you try to lube the threads before putting them in?
Old Feb 1, 2008 | 10:36 AM
CBR-runner's Avatar
CBR-runner
Yes, i have a huge jug of ARP lube
Old Feb 1, 2008 | 11:55 AM
stellar591's Avatar
stellar591
5th Gear
I'm new to LS motors and this thread is pretty interesting. I'm thinking about taking a similar route once I get a C5. I'll be following this to see how the end result turns out. Good luck!
Old Feb 1, 2008 | 08:41 PM
CBR-runner's Avatar
CBR-runner
well its almost done....
Old Feb 6, 2008 | 02:36 AM
Brad@RevXtremeAutoSports's Avatar
Nice job!!!
A good write up here -------> http://www.gmhightechperformance.com...ild/index.html
Old Feb 6, 2008 | 05:43 PM
CBR-runner's Avatar
CBR-runner
Thanks for the link! I had found that article a while back. It has been very helpful.
Old Feb 12, 2008 | 05:14 PM
CBR-runner's Avatar
CBR-runner
Well I'm still down one oil pump. What oil pumps and vender's do you guy recommend?
What do all of you guys think of the SLP ported oil pumps?
I also found this on the auction sight...
http://cgi.ebay.com/ebaymotors/CHEVY...ayphotohosting
Are they reliable?
I also need push rods. the stock size 7.4 are the right length. what do you guys recommend?
Old Feb 12, 2008 | 08:18 PM
Melling all the way. Don't skimp here.
Old Feb 13, 2008 | 06:02 PM
  #33
CBR-runner's Avatar
CBR-runner
well I'm going with the melling M10295 oil pump and 5/16 7.400 engine pro push rods.
I'll post pics of the M10296 (high capacity) and the m10295 (high pressure) pumps next to each other to show the size difference.
Old Aug 20, 2008 | 08:10 PM
  #34
CBR-runner's Avatar
CBR-runner
Well the motor is done and in, and the car runs like a top. With much thanks to LS1 power tuning in Charleston Sc.
So far the motor made 407rwhp @ 6500rpm and 383.99rwtq (peak @ about 3800rpm) on the stock air box and 93 pump gas. I have since added a halltech intake and am having the car put back on the dyno to finish the tune and get a real peak Hp#
The air system is sitting on the workbench.
The engine is built for a 200 shot of gas but I don't think i will get around to putting it in there.
